offroad pipe, elec. cutout?
Old Oct 23, 2003 | 11:43 AM
ucnu112's Avatar
Question offroad pipe, electric cutout?
I dug through the search for a while, and didn't find the answers I needed... so here I am.
I have new Hooker headers w/ a Y-pipe. I have 3" tubing running back into a Flowmaster. My question involves adding an electric cutout to the system.
Could I remove the cat, and put it in that location? Should I leave the cat? If I leave the cat, should I put the cutout before or after the cat? Maybe some combination of flowtech + offroad-pipe + cutout - cat = ??
I haven't test fitted any of the new components yet to see if any of these approaches would work (fit). The people I'm working with to do the work are welders and fabricators, so if they need to make something, it's not going to be an issue. Thanks for your help.
Fred
Old Oct 23, 2003 | 11:56 AM
GREGG 97Z's Avatar
Since you didn't mention LT's I'm guessing they are the Hooker shorty headers. I have SLP single cat shorty headers with their y pipe and I have an Cutout/ORP (I cut down an ORP and had it welded to a cutout) that I swap in in place of the single cat. I had to have a three bolt flange welded to the end of the y and then the same on the front of the ORP and Cat. it's real easy to swap them back and forth that way. You really can't run an ORP before the cat in it's stock location, theres no room.
Old Oct 23, 2003 | 12:50 PM
ucnu112's Avatar
You are right in guessing that they're shortys. I'm also lowering the car, so I didn't want to mess with clearance issues.
Do you swap the two components out often, or for certain situations? I'm forseeing that I won't probably put the cat back in, unless absolutely necessary. I don't have to worry about emissions.
Fred
Old Oct 23, 2003 | 01:02 PM
GREGG 97Z's Avatar
I had it made up so I could swap the cat back in for emmissions. I later I found I don't have to get emmissions done any longer so I just use the ORP all the time. If you don't have emmissions I would just weld the ORP up to the y.
Old Oct 23, 2003 | 02:25 PM
95 Silver TA's Avatar
If you go with an Electric Cutout...Go with DMH, see my write up and link below. He uses the best parts and warranties it for 4 full years. He makes cutouts for all kinds of cars from Domestic to Imports.
http://camaroz28.cardomain.com/memberpage/342629/5
Hope that helps,
Claude
Old Oct 23, 2003 | 02:30 PM
ucnu112's Avatar
Hope that helps,
Claude
Thanks I saw a thread where you had posted your site and his information, and emailed him earlier today. Definitely a quality product.
Fred
n2oblkz
Oct 12, 2015 01:53 AM
football4life
Oct 4, 2015 07:48 AM
Ks0209
Oct 1, 2015 07:32 AM
greenzee28
Sep 25, 2015 04:29 PM
tdigger9899
Sep 7, 2015 10:56 AM
