oem or aftermarket spark plug wires
Old Oct 4, 2005 | 05:04 PM
corbraeater's Avatar
just want to know what would better OEM or aftermarket one's like MSD?
Old Oct 4, 2005 | 05:09 PM
z28_theantirice's Avatar
Re: oem or aftermarket spark plug wires
MSD would be better
Old Oct 4, 2005 | 05:11 PM
2000GTP's Avatar
The OEM wires do a very good job, but considering the price similarities of both sets, might as well go with the MSDs. A set of red insulated wires will at least add some visual appeal to your engine bay.
Old Oct 4, 2005 | 10:00 PM
OBE1 95Z28's Avatar
Just a heads up that the MSD wires won't fit in the stock wire retainers; they're 8.5 mm. I've had excellent luck with the Accel 9000 wires and they're 8 mm so they can squeeze in the stock holders. They're around $70.
Old Oct 4, 2005 | 10:04 PM
Evil Eric's Avatar
I had accel 9000's and they burned up in less than 2 months, i have OTVC looms and coated headers. Accel products are cheap stick with MSD.
Old Oct 4, 2005 | 10:18 PM
OBE1 95Z28's Avatar
I've got 50K+ miles on my Accel 9000 wires on a blown car with JBA coated headers. No signs of wire failure here.
Old Oct 4, 2005 | 10:50 PM
Bersaglieri's Avatar
Another good word for MSD. I ran mine in stock locations with LT's, no problems. Much better product than stockers.
-Dustin-
Old Oct 4, 2005 | 11:06 PM
BlownF1's Avatar
LOL...if you burned a set of Accel 9000's, I assure you that they were installed improperly.
Old Oct 4, 2005 | 11:49 PM
MTL_Z28's Avatar
I run the 8.5 MSD superconductors in the stock wire retainers, I just had to carefully grind some of them in in some places in oder for the wires to fit, also I used LOTS of zip ties to make sure everything stayed in place and away from the headers.
Old Oct 5, 2005 | 07:56 AM
On a relatively stock car, stock wires are fine. Unless you are pushing some serious voltage through the wires, they don't need to be super low resistance.
Old Oct 5, 2005 | 08:12 AM
SoloExceptional's Avatar
I toasted two sets of MSD so not fond of their product, but it mighta been installation error, but I bought me a set of 8mm OTVC wires from elitesparkplugs.com and love em
Old Oct 5, 2005 | 08:52 AM
JasonK94Z's Avatar
I also got the OTVC kit from elitesparkplugs.com. Saves a lot of headaches on install. The stock wire locations suck for wire replacement.
Old Oct 5, 2005 | 09:01 AM
bond2's Avatar
Thumbs up Re: oem or aftermarket spark plug wires
I had a set of Accel 9000's put on at about 80k miles, have 136k miles on it now. The OEM wires melted. The Accel wires seem to be holding up extremely well. I think I got them at Summit Racing.
Forgot to mention they re-routed the wiring b/c the Accel wires were thicker and would not fit where the OEM wires were. They also took into consideration heat and tried to route the wires away from the hottest spots.
Old Oct 5, 2005 | 09:55 AM
Est96Z28's Avatar
Another vote for Accel 9000, 6 years and 0 problems !
Old Oct 5, 2005 | 12:07 PM
95patriotZ's Avatar
Another vote for MSD's. You have to route them differently then stock but it isn't hard and they work awesome!
