Odd problem
Old Dec 24, 2013 | 06:51 PM
jnw86's Avatar
Odd problem
I have a 94 Z28 A4 car with 112,000 miles that I purchased a few months back. I haven't had much time to mess with it, but I finally got around to it a little while today. The car ran horribly when I got it. I discovered that the CTS and the plug that goes to it were destroyed, so I replaced those and it ran better. Then, I had the ICM tested and it was also bad. Today, I replaced the ICM. Now the car runs great when you start it cold and revs perfectly. When the car enters closed loop, it still idles great and runs smooth. If I bring the revs up slowly it is perfect. The problem is if its at a steady rpm and you crack the throttle, it will backfire through the TB. If you start to bring it up slow and crack it the engine will rev perfectly. My thoughts are O2 sensors, MAF, or ECM. I thought maybe fuel pressure, but it wouldn't make sense for it to only be in closed loop. Anyone got any advice?
Old Dec 24, 2013 | 07:25 PM
Chet1185's Avatar
Re: Odd problem
Did you scan it for codes?
Sent from my LG-LS860 using Tapatalk
Old Dec 25, 2013 | 03:03 AM
jnw86's Avatar
Re: Odd problem
No I have not. Unfortunately, I don't have anything to scan it.
Old Dec 25, 2013 | 11:07 AM
Re: Odd problem
There's free 94/95 scanning software download link in a "sticky" on the "Computer Diagnostics......" forum.
Old Dec 25, 2013 | 02:56 PM
Chet1185's Avatar
Re: Odd problem
If you cant use the software, take it to an autozone.
Old Dec 25, 2013 | 03:13 PM
Re: Odd problem
It's often difficult to get OBD-1 scanned ar auto parts stores.
Old Dec 28, 2013 | 03:26 PM
jnw86's Avatar
Re: Odd problem
I cleaned the MAF and it runs yet better. Still, I have this issue. Once the car is up to temp it gets a rattling sound in the top end if you crack the throttle. Almost sounds like detonation. It also runs rough until you rev past this. If I unplug the cts to force it into open loop, it revs smooth, but still makes that rattling sound. Bad coil? It doesn't start until it hits 160 and gets worse all the way up to full operating temp. The intake elbow has a bad spot that might leak a little bit, but I wouldn't suspect that to be temperature related.
armedtrigger
Feb 24, 2015 08:30 PM
Red_94Formula
Jan 22, 2015 12:17 AM
jayblev95
Jan 20, 2015 01:30 PM
NewsBot
Nov 25, 2014 11:20 AM
JSK333
Sep 9, 2002 10:33 PM
