Odd LT4 intake question
Old Jul 31, 2006 | 11:41 PM
imnotfast's Avatar
Anyone ever get the red kryptonite paint off the intake? Have tried paint stripper, sanding, and oven cleaner....
Old Aug 1, 2006 | 07:31 AM
96azhawk's Avatar
Re: Odd LT4 intake question
I believe it's powdercoated You can take it to shops that do powdercoating and they can dip it in some chemical that can strip off the powdercoat. They can then powdercoat it whatever new color you want. Good luck.
Old Aug 1, 2006 | 11:56 AM
NJLT1SS's Avatar
You can go to Home Depot and get some paint stripper, comes in an can (brush on) or aerosol (spray). Put some on the intake, let it sit for about an hour, then start scraping it off. You will have to do this like 3 or 4 times, as I did. For the final cleanup, I took it to my friends shop and bead blasted it. Oh, and before you even start, remove all of the fittings, oil splash pan, and most importantly the casting plugs! After all of that, either take it to your local machine shop and have them run it through their jet was a few times, or use LOTS of soap and warm water, and a hose to get it squeaky clean. Then its ready for powder coat, or paint.
Nick
MadMav
Feb 6, 2015 11:02 PM
ModdedNerd
Jan 29, 2015 07:23 PM
Red_94Formula
Jan 22, 2015 12:17 AM
95chwagon
Jan 13, 2015 09:19 PM
