ODB1 and emissions
Old 09-24-2012, 11:58 AM
93zder's Avatar
ODB1 and emissions
Should my 1993 ODB1 system emit a code if there is something wrong with my emissions parts such as EGR or catalytic converter?
thanks
93zder is offline
Old 09-24-2012, 11:59 AM
RamAir95TA's Avatar
Re: ODB1 and emissions
EGR yes, cat no. Only OBDII cars utilize post-cat O2s to determine whether or not the cat is functioning.
RamAir95TA is offline
Old 09-24-2012, 12:36 PM
The only EGR function monitored on a 1993 is the electrical circuit/control.
shoebox is offline
Old 09-24-2012, 03:17 PM
93zder's Avatar
So the EGR valve could not be working properly and there would no codes to indicate this?
93zder is offline
Old 09-24-2012, 05:03 PM
mrmint69's Avatar
I bought block off plates on ebay for cheap and removed it. Then tuned it out when i got a mail order tune.
mrmint69 is offline
Old 09-24-2012, 05:13 PM
I believe that DTC 32 - EGR Circulation is applicable to the 93 model year. Chiltons shows it for 93, and Rob/Shoebox's LT1 code list does not show it as "N/A" in the 93 column on the right. That DTC cycles the EGR system and looks for an expected change in manifold absolute pressure (MAP). Code sets if the change is not detected. Problem is the OBD-I diagnostic does not appear to very very sensitive, and many people have completely deleted the EGR system without tripping the code. Maybe only 5% of the time it will set the code.
Injuneer is offline
Old 09-24-2012, 10:04 PM
Yeah, in a hurry I did not look closely at code 32. My bad. The sensitivity thing is still a concern.
shoebox is offline
Old 09-25-2012, 06:10 AM
93zder's Avatar
If i tune it out can the car still pass emissions testing?
Also, our emissions testing here includes a physical look to see that things are still there in place so removing and blocking them off would not be a good idea.
93zder is offline
Old 09-25-2012, 07:12 AM
Why are you worried about it? It seems you have no real trouble (at least that you have indicated).
shoebox is offline
Old 09-25-2012, 08:16 AM
93zder's Avatar
I failed emissions testing - and got it down to the CO being a little over on a re-test. So i still have something not quite right.
I was wondering if the EGR could be the or part of the problem.
I'm thinking it could be the Magnaflow cat not working 100%
93zder is offline
Old 09-26-2012, 08:41 AM
pgerst's Avatar
Bad EGR usually shows as high NOx. High CO is rich. As you have no codes for any bad sensors, my first guess is excess fuel from the injectors, and I would check first for leaking injector(s).
pgerst is offline
Old 09-26-2012, 11:27 AM
93zder's Avatar
I had them tested a couple years ago and they were fine - but that could have changed i guess.
Could it be the cat converter?
93zder is offline
Old 09-26-2012, 03:18 PM
Leaking injectors would show up as high HC.
What were the test results vs. limits for HC, CO and NOx?
Injuneer is offline
Old 09-26-2012, 03:22 PM
93zder's Avatar
They are:
limit Reading
HC. 52 21
CO. .29. .37
NO. 385. 298
The C0 is what's causing me to fail.
93zder is offline
Old 09-27-2012, 08:11 AM
pgerst's Avatar
This is a good summary:
Rich mixture
My personal experience was I was just barely passing on CO; I replaced injectors (on suggestion of smog guy) and reduced it to 1/3 prior levels. My understanding is high HC is more often bad ignition as it represents unburned fuel; high CO is more often bad injectors as it represents partial combustion of the fuel.
pgerst is offline
Quick Reply: ODB1 and emissions
