Obdii To Obd1 Conversion
Re: Obdii To Obd1 Conversion
Because OBD II has more sensors such as misfire detection thru crank position sensor and secondary O2 sensors etc and OBD I doesn't, so if you have heavy mods and don't want to throw codes you put an OBD I computer in your car and volia no codes and it's probably easier for custom tuners to work with when doing a mail order or custom tune.
Originally Posted by SPEED750
I've seen this mod posted a couple of times in peeps sigs. Why do people do this? Just trying to learn something new.
OBDI has Freescan (yes it's FREE) and OBDII has Autotap (~$450?). OBDI needs not O2 simms (~$20/side) if you remove your CATS. It's mainly a cost savings thing. I've heard OBDI is better for tuning some things but I'm not a tuner so I wouldn't know exactly what, I think it can handle slightly more airflow or something. If you have an automatic keep OBDII. I'm pretty sure the OBDI laptop interface cable is way cheaper too. Plus what everyone else already said.
If you go with a very high stall OBD1 processes slower and can become "confused" by the high slip and very fast acceleration and not shift right. My understanding though was this was not an issue with most TC used because most of us stay 2800-3500.
I run an OBD1 swap $100 for a cheapy laptop, $90 for Tunercat with the LT1 definition, $65 for a cable, $80 for Datamaster, and then a junkyard OBD1 pcm with $.20 worth of resistors and solder, all adds up to less than what JUST LT1 Edit for OBD2 costs and this is not VIN locked and includes an awesome datalogger. Just the swap and a cable would allow you to use email updates from one of the tuners that does such which is very nice otherwise with OBD2 you either spend $$$$$$$$$$$ on LT1 Edit for OBD2 so you can load or you have to mail pcm back and forth. If looking for basically a one time tune or infrequent updates with downtime being acceptable or you are willing to do the core thing Ion's OBD2 programming is VERY reasonable.
RUENUF
Mar 13, 2016 03:37 PM
Henson071
Dec 30, 2015 09:55 PM
tdigger9899
Sep 7, 2015 10:56 AM
