OBD2 LT1 programming ... what are my options?
Old Jul 10, 2003 | 12:31 AM
pillagenburn's Avatar
just like the subject implies .... for OBD2 LT1 PCM's .... am i basically stuck with LT1 edit for tuning myself, or is there something else out there?
thanks!
Old Jul 10, 2003 | 12:37 AM
1982z28with18s's Avatar
Could do an OBDI swap.
Old Jul 10, 2003 | 12:40 AM
BadRag's Avatar
Another choice is pcforless
BadRag
Old Jul 10, 2003 | 01:37 AM
InjectedSS's Avatar
your best bet! OBD1 PCM, OBD1 knock sensor and TUNERCAT! then you will be unstopable well until you get to 7000rpms of course
Old Jul 10, 2003 | 02:12 AM
Teek's Avatar
Ed Wright does OBD2.
www.fastchip.com
Old Jul 10, 2003 | 08:41 AM
All_Z_Way's Avatar
Either use LT1 edit or swap out your PCM for an ODB1, which is what I did. Then you can use either Tunercat or the cheaper version of LT1 edit.
You could always use mail order tuning too.
Old Jul 11, 2003 | 04:30 PM
one problem....
only problem with an OBD1 swap .......
any hopes of ever passing emissions go right out the door.....
thanks
Old Jul 11, 2003 | 04:33 PM
Mr Z28's Avatar
And you have high stall converter lock-up issues being compatible with OBD1
Old Jul 11, 2003 | 04:35 PM
Mr Z28's Avatar
Sorry M6 car - I should read before I post
Old Jul 11, 2003 | 05:13 PM
turbo_Z's Avatar
Madwolf does OBD2 tuning now. I cant comment on this price... less than $150 i think but am not certain. you can check it out at www.madz28.com ... he is also a paying advertiser here so with all things equal (him and pcmforless.com)... hes your best choice. as other have said you could also toss in an OBD1 pcm and get somethin like tunercat for less than LT1edit and CONSIDERABLY less than LT1edit for OBD2 cars.
HectorM52
Jul 30, 2017 11:46 AM
Sergio
Jan 27, 2016 04:27 PM
Dec 23, 2014 07:52 AM
Jul 4, 2005 05:00 PM
Redbird
Jul 20, 2002 06:08 AM
