obd2 connector on obd1??? it fit but...
Old Feb 28, 2005 | 07:42 AM
nonamez28's Avatar
ok well i went to auto zone to try and figure out my mysterious check engine light code that comes on occasionally... and we were trying to find the obd1 connector but he said that the obd2 should work because soem of them were obd2 compatable??!?! i was like ok, because i really dont know..
well the connector fit but the computer wouldnt link up? is this because my car just isnt obd2 and the connector might fit but it is different? or what?
thankyou for the help
Old Feb 28, 2005 | 07:53 AM
Re: obd2 connector on obd1??? it fit but...
The 1995 LT1 f-body uses an OBD-II shaped connector, but an OBD-I computer. It requires a special cable when using a scanner. Autozone usually will not scan it, because they normally only scan OBD-II cars.
Old Feb 28, 2005 | 12:23 PM
nonamez28's Avatar
thankyou, now i just need to find the obd1 connector
Old Feb 28, 2005 | 12:54 PM
No... you need to find a shop that has the converter that allows them to plug an OBD-I scanner into your OBD-II ALDL connector. Or you need to go to Shoebox's website and learn how to make the conversion yourself.
Old Feb 28, 2005 | 01:06 PM
CreatiVe2's Avatar
my friend has a 1995 z28 also... same exact problem, he took it to pepboys, had them scan it.. (omfg dont ever let them do work) it turned out to be his AIR and MAF.... he fixed them himself...
HectorM52
Jul 30, 2017 11:46 AM
Richardan15
May 30, 2015 08:36 AM
97TA-WS6-Con
Feb 1, 2015 01:01 PM
Camaro_Eric
Aug 8, 2002 12:21 PM
