OBD1 Swap problems,, please help
Old Mar 5, 2006 | 04:28 PM
walt355's Avatar
Started the car today, drove it up the road, ran good. Pulled it back in the shop and put the OBD1 in, also took the LT4 KM out of my OBD2 and put it in the OBD1. Fired the car up. Ran it for maybey 10 seconds, wouldnt Idle, ran like ****(so I figured with no tuning. Went to download the stock tune from the OBD1 using tuner cats and a patch cable I bought off of this board for a OBD1 with an OBD2. When I go to download the tune is says establishing connection. After the Progress bar gets about half way the fans kick on and it says something about a wrong signal error, click OK then it says connection attempt terminated. Any suggestions??
Old Mar 5, 2006 | 04:40 PM
2fast97z's Avatar
Re: OBD1 Swap problems,, please help
ok well i use tunercats and the fans turning on is no big deal they turn on all the time while doing it....now the part about half way and it saying something about a wrong signal error i have no earthly idea what that could mean...mine has never done that...my friend was using it and didnt want me to do it(bad move) he was trying to find other features and hit the program ecm menu thinking there was more menus and after it had already started down the progress bar he just clicked cancel and first off his was a completely stock 95 z..and i have a 97 in open loop with wayyy diff options..he was loading my tune onto his car and it only loaded half...fried his ecu like crazy...car had to be towed...so dont **** with tunercats....let people that know how to do it use it...back to that i would just try it again also you should down load a program called freescan V2.10 easy program that you can use the same way just to read sensors and look at rpms and make sure your ecu is stilll running right...other than that i dont think i can help any more
Old Mar 5, 2006 | 04:43 PM
turbo_Z's Avatar
Download the newest version of Tunercat. The old version would run the fans for the whole read/write but the new version kills them after the connection is established. If the fans are interfering too then just pull the fan fuse and see if that helps.
One problem I see though is you need to get the correct knock sensor. OBD1 and OBD2 KS are different.
Old Mar 5, 2006 | 05:02 PM
walt355's Avatar
Damn, I didnt know that about the Kock Moduals. Ill pull the ran fuse and try in again;. My buddy told me that if the battery is not at the correct voltage that is will not conect. Ill see what happens. thanks fellas
Old Mar 5, 2006 | 05:38 PM
walt355's Avatar
Well, I tried putting a trickle charge on the battery, Pulling the Fan fuse and relays. Still gives me a Incorrect message sent error.
Old Mar 5, 2006 | 05:49 PM
ejfagala's Avatar
THe Knock Module is the same re-read the previuos post it is the Knocke sensors. You need OBDI sensors for the OBDI ECM or it will run like poo and throw a SES code.
Old Mar 5, 2006 | 05:54 PM
walt355's Avatar
I have installed a OBD1 knock SENSOR. I reused the knock Modual out of my OBD2. After doing some searches I read that the KM is the same.
Old Mar 5, 2006 | 06:02 PM
turbo_Z's Avatar
Right the knock modules are the same but the sensors are different. It makes no sense why the knock module would cause the car to run bad though. Why are you reading the OBD1 for?
Old Mar 5, 2006 | 08:23 PM
walt355's Avatar
Well, I dont know if it runs bad or not. I dont really care at this point. Im just tring to get the car to interface with CAts
Old Mar 5, 2006 | 09:54 PM
turbo_Z's Avatar
Try another computer. And to make sure the cable is not your problem, try getting some logs using Datamaster and see if the same communcation break is present. If I had to make a guess Id say the problem is the laptop you are using... can you describe it?
Old Mar 5, 2006 | 10:40 PM
walt355's Avatar
Its an HP
ch3vyb1gbl0ck
Classic Engine Tech
Oct 23, 2023 08:07 PM
jj_burchiel
Mar 5, 2015 07:05 AM
Zee man
Feb 12, 2015 07:07 AM
rocketman051894
Jan 30, 2015 03:23 PM
