OBD1 and OBD2 questions
Old Jan 7, 2006 | 03:35 PM
  #16
Dave '97 Z28 M6's Avatar
Re: OBD1 and OBD2 questions
Originally Posted by ponyackn
So when you get smogged here in CA, do you have to swap back to the obd2? Or do have to have someone "look the other way"? I've considered this but don't know if the machine that it's hooked up to will register that the computer doesn't match the car's vin
My OBDI conversion PCM is programmed with my VIN.
Up here our e-test (every 2 years) is a sniffer, so they don't plug into the computer. All they do is look for a functioning SES light, and verify that it is not "on", and then perform the sniffer on a chassis dyno.
I'm not familiar with the test procedures in the various states, but I know some do a sniffer test, whereas other states will "plug-in" to an OBDII car to check for faults, readiness indicators, etc.
You need to find out what the exact testing procedure is in CA. If they plug-in, you're stuck with OBDII (which is not really a bad thing).
You could get an OBDI conversion PCM, and then have your OBDII PCM programmed specifically for the e-test. Then, a few days before your e-test, swap in the OBDII PCM with the conservative tune (drive around a bit - don't go into the test while the PCM is still "learning"). I know things are pretty strict in CA, so that might be a way to deal with it.
Old Jan 7, 2006 | 03:51 PM
  #17
ponyackn's Avatar
Thanks Dave. It is a plug-in, as far as I remember. I may try having an obd1 to swap in like you said. Don't know if it's worth the extra cost and hassle though.
Old Jan 7, 2006 | 04:06 PM
  #18
I would say probably not. But despite saying that, that's basically what i've done, except I haven't used the OBDII PCM. I haven't actually had to take an e-test with my current setup - that comes this summer. If it doesn't pass, I could get a custom emissions tune for the OBDII PCM, or I could use my laptop + cable to flash the OBDI PCM with an emissions tune. Either way, I'll cross that bridge when (and if) I come to it.
A lot of guys like the plug-in test. Some states (apparently) just do a visual check and then plug-in to the OBDII. There are guys with hollowed-out cats (to pass the visual) and wicked cams that can pass e-tests simply because they have a well-programmed OBDII PCM, and don't have to pass a sniffer test.
HectorM52
Jul 30, 2017 11:46 AM
oldschool
Feb 9, 2016 09:21 PM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
Hurin
Dec 13, 2014 07:38 PM
