OBD1 or OBD2
Old Oct 23, 2011 | 02:50 PM
z86trev's Avatar
OBD1 or OBD2
So I went to scan my 95 z28 and the plug is the OBD2 style. I used the OBD2 adapter and it wont read the car. The 95 plug wont fit. ANy suggestions? thanks
Trev
Old Oct 23, 2011 | 03:01 PM
JGuy07's Avatar
Re: OBD1 or OBD2
It's an obd2 style connector with an obd1 pcm....make sure whatever you're scanning with is obd1 compatible. What are you using to scan, a scan tool or computer software?
Old Oct 23, 2011 | 03:30 PM
jit11375's Avatar
Re: OBD1 or OBD2
http://shbox.com/1/xraycable.jpg
i assume ur using an obd1 scanner cuz u said ur using an obd2 adapter, so that diagram shows how to connect it
Old Oct 23, 2011 | 06:33 PM
z86trev's Avatar
Re: OBD1 or OBD2
Wow! Awesome, and it worked. So it came up with the following : 29, 48 and 84. One was maf flow problem, one was 3 to 2nd gear downshift and one was an electrical fault. Off to research. . .
Thanks for the help
Old Oct 23, 2011 | 06:43 PM
Re: OBD1 or OBD2
DTC 29 is usually a blown fuse for the AIR pump. If you replace the fuse and it continues to blow, thepump is probably siezing up from corrosion. Pull the harness connector off the AIR pump, then replace the fuse. The pump won't work, but it will get rid of the code and SES light.
DTC 48 can either be a faulty harness or a faulty MAF sensor. With key on/engine off, check the voltage between the pink and black/white wires in the harness connector. Should get 12V. If you have 12V, its a faulty sensor.
DTC 84 is for the 3 to 2 downshift solenoid only if your car has an automatic trans. If you have the manual trans, DTC 84 indicates the skip shift solenoid has been disconnected, or if its still connected, check the fuse.
You need to add a "Signature" with basic info about your car - year, model, engine, trans and any major mods. That way people have most of the info they need to help you.
Old Oct 23, 2011 | 07:09 PM
z86trev's Avatar
Re: OBD1 or OBD2
Thanks for the info man! Signature updated.
Old Oct 23, 2011 | 07:12 PM
jit11375's Avatar
Re: OBD1 or OBD2
ny eh? queens here! don't see too many lt1's runnin aroundd
Old Oct 24, 2011 | 12:47 PM
z86trev's Avatar
Re: OBD1 or OBD2
I wonder if the big rip in the intake boot has anything to do with the Mass Air code? LOL
Anyone know where I can get one. I had about 3 laying around from the various caprice and impalas that I have had, but cant find any.
Old Oct 24, 2011 | 01:00 PM
raulz28's Avatar
From: 5 minutes from the warzone in mexico(south texas)
Re: OBD1 or OBD2
Yea that rip would have something to do with it since there is that unmetered air going into the engine which the MAF can't compensate for. I would go for an aluminum elbow that's what I did after mine ripped.
Old Oct 25, 2011 | 05:15 AM
Re: OBD1 or OBD2
The OBD-I code for the MAF sensor is based only on the electrical circuit being complete or not complete. Only OBD-II has codes for rationality of the MAF sensor reading.
The tear in the inlet elbow is probably causing it to run worse than it should though. Why would you drive it like that?
Old Oct 25, 2011 | 06:59 AM
z86trev's Avatar
Re: OBD1 or OBD2
I drove the car less than ten miles from where I bought it. I am trying to handle all of the issues before I put it on the road. thanks
Old Oct 25, 2011 | 09:32 AM
Psycho's Avatar
Re: OBD1 or OBD2
I easily repaired my boot with black rtv and some patience. I used a plastic bag to keep the rtv from sticking where it shouldn't until the rtv setup, usually 18-24 hours. The screw clamp band hides most of the work and it looks fine.
Sep 6, 2015 03:10 PM
Aug 24, 2015 06:41 AM
whitehooptie
Aug 10, 2015 07:02 AM
Aug 7, 2015 01:26 PM
Pullngz
Jul 26, 2015 05:55 PM
