OBD I scan
Old Mar 10, 2004 | 06:27 PM
KillWhitey's Avatar
OBD I scan
is there anywhere that i can get my 94 z scanned for an ses light for free like an OBD II?
Old Mar 10, 2004 | 06:35 PM
Brent94Z's Avatar
Super Moderator
Your local AutoZone will do it for free for ya.
Old Mar 10, 2004 | 06:36 PM
KillWhitey's Avatar
Sweet. Thanks
Old Mar 10, 2004 | 07:39 PM
I'm pretty sure Autozone only scans OBD-II.
Old Mar 10, 2004 | 07:42 PM
Brent94Z's Avatar
Super Moderator
Hmm... I'll find out for sure but I thought at least our local Autozone did OBDI. At least they advertise they do
Old Mar 10, 2004 | 07:59 PM
Yours might, but from what I have observed, most don't.
Old Mar 10, 2004 | 08:01 PM
Spinner's Avatar
Autozone here only does OBD2
Old Mar 11, 2004 | 03:21 PM
KillWhitey's Avatar
Yep... auto zone worked, but when he plugged the little thing in the port the shift light went off and the fans came on and the ac comp jumped a little. The guy got all confused. A person inside told me that it needed to have a running diagonistic done at a dealership. How much is that?
Old Mar 11, 2004 | 03:24 PM
You say "worked", but did it? Get any codes? What did they plug into the DLC? Why would they turn around and tell you to go to the dealership?
Old Mar 11, 2004 | 03:54 PM
KillWhitey's Avatar
The local auto zone could scan my 94 but they told me that since the ses light only came on after about 2 minutes of driving that i had to take it to a dealership to get a running test. At auto zone the guy plugged a little piece of metal into the port to make a connection that he said would make the ses light blink giving him the code and it did not work. The person inside said that since it only came on when i was driving that i had to go to a dealership to get the proper scan.
Old Mar 11, 2004 | 04:02 PM
moparman's Avatar
You will need a scan tool or code reader that works with OBDI to pull the code. If you buy either of those, be sure it will do what you want, as not all tools will do it. You can not short the pins after '93.
Old Mar 11, 2004 | 04:05 PM
KillWhitey's Avatar
where can i get a scan tool or code reader and how much does something like that cost? What your telling me is that i dont have to go to a dealership to get it done?
Old Mar 11, 2004 | 04:19 PM
moparman's Avatar
There are hand held units, such as those by Actron and Autoxray, and there are programs made to work with laptops and desktops. It depends on how much money you can afford to spend. Check E-bay for "OBDI scan tools" for starters. Or do a search for the same thing. Injuneer Fred has a good write up on them, if you can find it. I think there is a group purchase on the Scan Master for around $225.
Old Mar 11, 2004 | 04:31 PM
KillWhitey's Avatar
Could i get it scanned for cheaper at a dealership?
Old Mar 11, 2004 | 04:48 PM
KillWhitey's Avatar
Lightbulb
So if OBI-wan Kenobi got in to a fight with Spock, with Frodo as a guest referee, who would win?
