OBD I or II?
Old Jun 21, 2004 | 06:55 PM
R8E1D's Avatar
OBD I or II?
How can you tell the physical difference? I have had my motor torn down and found lots of goodies that i had not known were there. Like a bigger comp cam, rr's, springs, forged pistons, and the heads and intake have been ported and polished. I have done the research and found this to be my next step. However I dont know if the previous owner has done it or not. Which is my question. Are there any numbers or physical differences? Thanks in advance!
Old Jun 21, 2004 | 07:01 PM
The differences are mainly in diagnostic capability and not many physical items. Definitely nothing internal to the engine has to do with the difference between the two.
You will have a few extra sensors, like crank position sensor in the timing cover, post cat O2 sensors, EVAP vacuum switch and maybe another thing or two that I can't think of off the top of my head.
A 1996 would be OBD-II stock. Checking with a scanner would tell you if it had been swapped.
Old Jun 21, 2004 | 07:03 PM
R8E1D's Avatar
Is that the only way to check shoebox?
Old Jun 21, 2004 | 07:06 PM
If the PCM was swapped, all those sensor could still be physically present, but just ignored. You might be able to tell by part number on the PCM, itself, but I don't know what the numbers are. Someone like Ion at http://madz28.com could probably tell you.
Old Jun 22, 2004 | 11:42 AM
madwolf's Avatar
There is a label with a service number on the PCM.
16214399 - corresponds to a 96 [OBDII] PCM
16188051 - 94-95 [OBDI] PCM
Old Jun 22, 2004 | 12:02 PM
R8E1D's Avatar
Thanks guys! Ill check it out tonight.
Novo
Jun 14, 2016 02:58 AM
4586
Sep 6, 2015 03:10 PM
whitehooptie
Aug 10, 2015 07:02 AM
Aug 7, 2015 01:26 PM
Aug 7, 2015 08:52 AM
