Are O2's Necessary
Old Jan 22, 2007 | 07:49 PM
  #16
user 647483's Avatar
Originally Posted by 93 4mula
Then I could run a narrow band in one header and then put the wide band in the other and tap it into the ecm so its used for both a/f ratio and tells the ecm what to do.
You really want to leave both narrowband O2s in there.
The ECM needs to know what is happening on both sides of the engine.
You don't gain anything by removing them.
If you want to add a wideband for diagnotics, logging or otherwise, have an
extra bung welded in. I did a lot of my fine tuning that way.
