O2 sims and emissions
Old Aug 19, 2004 | 01:12 PM
Makaveli's Avatar
i thought ive read about this here before, but i cant seem to find anything i need in a search. i have a 96 Z28, dual cats etc. if i switch to single cat headers, with air and egr, use a single cat, and O2 sims for the rear O2s, will i still be able to pass emissions?
in CT here now i believe they plug in something to the OBDII cars and it reads if you are throwing codes or not... would using O2 sims, or having them reprogrammed be recognized by the emissions check?
Old Aug 19, 2004 | 01:16 PM
Kraest's Avatar
Retired
Re: O2 sims and emissions
The sims make the computer think that the rear o2 sensors are there, so there won't be a code thrown. I doubt you'd have a problem.
Mike
Old Aug 19, 2004 | 01:32 PM
Makaveli's Avatar
just what i wanted to hear, thanks
Old Aug 19, 2004 | 02:30 PM
Firehawk_Dude's Avatar
Is there an easy way around OBDI emissons? That is all that is kind of holding me back.
Old Aug 20, 2004 | 11:49 AM
Gos2Slo's Avatar
Not exactly, the O2 sims only prevent the light from coming on, but on a scanner at a smog shop, O2 sims will set AT LEAST two "sensor not ready" lights. Check with injuneer, but O2 sims won't get you through a smog check.
Old Aug 20, 2004 | 04:32 PM
Anyone know a way around a smog test? Like i said that is the only thing holding me back. I live in IL so its not the worst as far as emissions go but they are still strict enough to not let me get long tubes.
Old Aug 20, 2004 | 09:01 PM
Makaveli's Avatar
ah, thats exactly what i remembered reading the first time, any more specifics?
if this is true, it would seem anything but emissions legals shorties are my only choice. not only are they a bad design, they are so much more money than regular headers... unless i fab a dual cat y pipe.
thanks!
Old Aug 20, 2004 | 09:08 PM
96capricemgr's Avatar
OBD1 is EASY to make pass even with a fairly wild combo, all you need is decent tuning and good cats for the emmisions part, any visual check could easily be harder to pass with a modded car.
On the original question, would it be so bad to just install both O2s behind the one cat? I mean if there is a cat there they should read good.
Old Aug 20, 2004 | 09:18 PM
Makaveli's Avatar
i never thought of that... i dont see why it wouldnt work?
Old Aug 21, 2004 | 12:00 AM
mrz28 73/97's Avatar
Well what if you have an OBD I conversion in a 96 - 97 car will it still pass the computer scan or will the scan reveal the PCM switch?
sleeperZ96BT
Sep 9, 2015 08:28 AM
GusarskiSS
Exhaust System
Sep 2, 2015 03:51 PM
sherwinZ28
11
Aug 15, 2015 05:38 PM
joffer00
Exhaust System
Dec 22, 2014 03:25 PM
Hannibal
Sep 6, 2002 05:07 AM
