O2 Sensors and OffRoad Y Pipe HELP!!!
Old Nov 29, 2003 | 10:49 AM
My 97 Z28's Avatar
I am ordering a stainless works offroad Y pipe from Summitracing, and I have just a few questions on it. WHat do I do about the fromt O2 sensors, does it have a hold in the pipe already for it to go into? And I am putting O2 Simulators in the rear, and once i put the simulators in, then what do I do with them? I've never done anything with an offroad Y pipe before and wondering what I need to do?
Old Nov 29, 2003 | 10:55 AM
AsianSensation's Avatar
I assume you still have the stock exhaust manifolds? The two pre-cat O2 sensors will stay where they are, on the exhaust manifold.
Old Nov 29, 2003 | 11:01 AM
My 97 Z28's Avatar
Yeah I have stockers for now. I'm just 16 and learning about my Z still. Do I need the harness extensions or what do I do about my O2 Simulators. Where do I put those after I put them In place of the O2 sensors?
Old Nov 29, 2003 | 11:07 AM
You do not need an O2 sensor extention wire harness (for pre-cat O2 sensors only) since your pre-cats O2 sensors will stay where they are. You put the O2 sims (need 2) in place of the post-cats O2 sensors, one behind each cat. Just plug then up where the post-cat O2 sensors plug up at. Zip tie it down.
Old Nov 29, 2003 | 11:10 AM
My 97 Z28's Avatar
I won't be running any cats, but do I just zip tie them down anywhere but the pipe?
Old Nov 29, 2003 | 11:15 AM
I meant the post-cat O2 sensors is located behind the cats (1 per cat). Ya, secure it down so the O2 sims won't bounce up and down.
Old Nov 29, 2003 | 11:17 AM
My 97 Z28's Avatar
Thank You
Old Nov 29, 2003 | 11:24 AM
jchevy's Avatar
If you need instructions on how to do an egr simulator let me know. You may be ok since you dont have headers, but i kept getting an egr code when i installed my ORP.
Speeds8erM-1
Aug 20, 2002 09:12 PM
Speeds8erM-1
Aug 15, 2002 10:07 PM
Speeds8erM-1
Aug 13, 2002 10:24 PM
Speeds8erM-1
Jul 28, 2002 06:18 PM
Speeds8erM-1
Jul 18, 2002 11:36 PM
