O2 sensors or O2sims with Jethots on OBD1
Old Sep 29, 2003 | 09:39 PM
boxerfreeflow00's Avatar
any opinions or ideas about this?
thanks
Old Sep 29, 2003 | 11:25 PM
"Sims" are only intended for use on the "after-cat" O2 sensors found on the OBD-II (96/97) cars. They can not be used on the pre-cat sensors. So... you have no choice on an OBD-I setup. You must run the O2 sensors, or run the PCM in open loop (not recommended).
14
Aug 11, 2015 12:03 PM
whitehooptie
Aug 10, 2015 07:02 AM
Aug 7, 2015 01:26 PM
Pullngz
Jul 26, 2015 05:55 PM
88IROC_Z
Jul 22, 2015 11:38 PM
