O2 Sensors keep going out!
Old Jul 15, 2008 | 12:11 AM
  #16
charliediss's Avatar
Originally Posted by Injuneer
Have you checked for intermittent readings from the coolant temp sensor in the water pump housing? If the coolant temp indicates low enough, it will drop out of closed loop, and the PCM will start to richen the A/F mixture because it thinks the engine isn't warmed up.
No, I havnt checked the sensor reading from the coolant temp sensor yet, that will make it to the top of my list for things to check when I get home. I am also going to pick up a set of AC Delco O2s, anything else you can think of?
Old Jul 15, 2008 | 12:25 AM
  #17
Since you have long tubes, you probalby have extensions. Have you checked the extensions for a ground leak to the purple (or purple/white) signal wire? That would cause the O2's to read super lean, forcing the PCM to add fuel the engine doesn't need.
Old Jul 15, 2008 | 04:56 AM
  #18
Thumbs up
That sounds very possible because even after I put new O2s in there, that bank smells rich, I guess that is also going to be an avenue of approach as I prep the car to hit the road once more. Thanks Fred, if you think of anything else, I would really appreciate the thought.
You have been a huge help
Charlie
generaldave
Sep 25, 2015 06:48 PM
98-LS1Z28
Sep 8, 2015 03:12 PM
350350
14
Aug 11, 2015 12:03 PM
whitehooptie
Aug 10, 2015 07:02 AM
Aug 7, 2015 01:26 PM
