o2 sensors
Old Nov 24, 2005 | 04:33 PM
97formulakid's Avatar
o2 sensors
where is the cheapest place i can get some stock 02 sensors???? anyone??
Old Nov 24, 2005 | 05:27 PM
Grn4fbody's Avatar
Re: o2 sensors
which one do you need? The down pipe sensors or the manifold ones? Ill Sell ya a DownPipe o2 sensor that i used for maybe 200 Miles
Old Nov 24, 2005 | 06:52 PM
toegead93's Avatar
Re: o2 sensors
Try Brasington www.gmotors.com or gm parts direct. If there anyplace cheaper I'd like to know also. I'm placing my order tomorrow.
Old Nov 24, 2005 | 11:14 PM
Robert95z's Avatar
Re: o2 sensors
http://store.getgmparts.com/es10006.html
Old Nov 25, 2005 | 12:17 PM
SantaCruz163's Avatar
Re: o2 sensors
Call Jason Cromer at Sam Taylor Buick in Florida.
877 726 8295
Old Nov 26, 2005 | 03:56 PM
Re: o2 sensors
now im not sure which ones i need. I am getting longtubes with an ORY so I would need the manifold ones right??? I am going to have the rears tuned out when I get my tune from Madwolf.
Old Nov 26, 2005 | 04:00 PM
2000GTP's Avatar
Re: o2 sensors
Yes you need the manifold ones.
Old Nov 26, 2005 | 07:55 PM
Coop1's Avatar
Re: o2 sensors
Hey Robert95 is that O2 sensor that you showed the one for the manifold?
Old Nov 26, 2005 | 08:32 PM
Robert95z's Avatar
Re: o2 sensors
Not sure what you mean as all O2 sensors are the same on your vehicle. The link i showed you is the one you need.
Old Nov 26, 2005 | 11:10 PM
1racerdude's Avatar
Re: o2 sensors
Remember to run it for an hour or so with the old ones. The crap inside the new headers may mess up the new ones.Then put the new ones in.
Old Nov 26, 2005 | 11:42 PM
Re: o2 sensors
You need pre-cat sensors.
All four sensors are not the same. The pre-cat sensors have a different connector than the after-cat sensors. One is flat, one is square, they are not interchangeable.
Pre-cat: AFS75 NP 25312184
After-Cat: AFS97 PN 25312196
generaldave
Sep 25, 2015 06:48 PM
98-LS1Z28
Sep 8, 2015 03:12 PM
350350
14
Aug 11, 2015 12:03 PM
whitehooptie
Aug 10, 2015 07:02 AM
Aug 7, 2015 01:26 PM
