o2 Sensors
Old Jan 27, 2005 | 02:01 PM
aintno6's Avatar
o2 Sensors
I just got a lt1 scanmaster for my car, and I have been playing around with it, and I'm getting basic info on the way this puppy runs.
Here is my question. How accurate is a healthy gm heated o2 sensor compared to a wideband o2. Basicly, the reading I get from my scanmaster at WOT, how accurate would you say those are? Are they most likely lower or higher?
Just wondering. Because before my tune and delteq install I pulled around 12.5:1 a/f at the dyno day. And now doing a few small wot runs on with the tune and delteq, it looks like im running healthy at a 14:1 a/f. I know I need to go back to the dyno to be sure. But I wanted to get some input on how accurate these stock o2 sensors are.
Thanks,
Mike
Old Jan 27, 2005 | 02:50 PM
OBE1 95Z28's Avatar
Re: o2 Sensors
Stock O2 are narrow band, meaning that they are only accurate in a very narrow range centered around 14.7 afr. You should not use these to tune your car!
Old Jan 27, 2005 | 03:17 PM
aintno6's Avatar
Re: o2 Sensors
I realize that, but I wondering how accurate they are.
Mike
Old Jan 27, 2005 | 05:58 PM
Re: o2 Sensors
The problem is that the OEM narrow band sensors have a very flat curve of mV vs A/F ratio. As a result, it takes a very large change in A/F ratio to make a very small change in mV's, when you are up around 12.5 - 13.5:1. And, the mV output at these A/F ratio levels is very sensitive to operating temperature. Hence a small change in operating temperature can produce a large change in mV's, masking the change produced by the true A/F ratio change.
I'm a little surprised that you are finding the car runs at peak performance at 14:1.... most people find the best results in the range of 12.8-13.2:1, with maybe a few people running up to 13.4:1. How did you use the ScanMaster readings to determine you are "running healthy at a 14:1 a/f."?
Old Jan 27, 2005 | 07:55 PM
aintno6's Avatar
Re: o2 Sensors
Looks like I'm going to have to get her on the dyno soon. I figured I should to see how much I have gained with the tune and delteq.
Fred the reason why I say its running healthy is because before the tune the best I could turn was 13.8@101 with all the bolt-on's I had. Plus the car had poor gas milage, and was running pretty rich. I was told several local lt1 folks, that with the a/f I was pulling, it was pretty simple to see that the car was in need of tune, and was running rich. Since the tune and delteq I have dropped m y et by .4ths and gained 3mph in the 1/4. The runs much better. And looking at the scanmaster readings on some short WOT runs, I'm not getting any knock, and evry thing seems normal.
I was basing the a/f readings to MV readings of sites info like on here http://www.speedshop.org/store/scrip...p?idproduct=15
Thanks,
Mike
generaldave
Sep 25, 2015 06:48 PM
98-LS1Z28
Sep 8, 2015 03:12 PM
350350
14
Aug 11, 2015 12:03 PM
whitehooptie
Aug 10, 2015 07:02 AM
Aug 7, 2015 01:26 PM
