O2 Sensors -- 2 for A/F and 2 for ??
Old Oct 12, 2003 | 01:50 PM
Stoopalini's Avatar
It's my understanding that the front 2 oxygen sensors are used to calculate what the A/F ratio should be and the rear ones are used to determine if the cats are doing thier job.
My question is, does the PCM make any adjustments at all based on the rear O2 readings or are they just there for emissions reporting when a scanner is hooked up?
Thomas.
Old Oct 12, 2003 | 02:02 PM
The pcm does not use the rear O2s for any calculations. They are only there to watchdog the cats (hmm, a funny ), part of OBD-II.
Old Oct 12, 2003 | 02:16 PM
Stoopalini's Avatar
LOL Thats exactly what I needed to know!
Thanks Shoebox,
Thomas.
Old Oct 12, 2003 | 04:04 PM
Stoopalini's Avatar
The front O2's look like this and the rear ones look like this
I don't know if they are mechanically the same, but as the pics show, the connectors are different; so, no, you can't just swap the fronts and rears to see if that's your problem
Thomas.
edit: I just noticed you have a '95, isn't that ODB I? If so, doesn't OBD I only have 2 O2s alltogether? I think OBD II ('96+) started with the extra O2 sensors after the cat ....
Henson071
Dec 30, 2015 09:55 PM
98-LS1Z28
Sep 8, 2015 03:12 PM
whitehooptie
Aug 10, 2015 07:02 AM
Aug 7, 2015 01:26 PM
Henson071
Aug 4, 2015 09:32 AM
