Is O2 sensor supposed to be canted or straight?
Old Apr 28, 2005 | 01:59 PM
joey93turbo's Avatar
I noticed the O2 sensor on the right side of my engine is slanted like it got hit real hard with something. Is it supposed to be like this? I'm still trying to fix this problem with the car running too lean...
Old Apr 28, 2005 | 02:25 PM
BLinindoll's Avatar
Re: Is O2 sensor supposed to be canted or straight?
O2 sensors are supposed to be straight. Every O2 sensor on your car should be exactly the same.
Old Apr 29, 2005 | 07:16 PM
What's the best way to test it?
Old Apr 29, 2005 | 07:34 PM
93transam1234's Avatar
sheet ifit is bent i would go ahead and replace it, the best way to test it would be if you have a scanner you could switch the left and right 02's and see if the problem follows to the other side
DirtyDaveW
Dec 1, 2016 05:37 PM
Dzmaro
May 7, 2015 09:33 AM
MattFick
Feb 15, 2015 10:16 PM
cmdeshon
Jan 4, 2015 11:15 AM
Makaveli
Jul 24, 2002 11:27 PM
