o2 sensor miss?
Old Apr 11, 2006 | 03:39 PM
1996z28m6's Avatar
o2 sensor miss?
Could the Driver side Bank 1 o2 sensor cause a high rpm miss? The reason im asking is because i have a persistant high rpm miss along with a low rpm bog, and the only code occassionally being set is the driver side bank 1 o2 sensor.
Old Apr 11, 2006 | 04:19 PM
valter's Avatar
Re: o2 sensor miss?
What code? I had a low rpm bog with bad O2's.
Old Apr 11, 2006 | 04:27 PM
1996z28m6's Avatar
Re: o2 sensor miss?
cant remember the code, but it said bank 1 sensor 1 high voltage or something like that
Old Apr 11, 2006 | 04:46 PM
Re: o2 sensor miss?
You need the exact code.... there are at least 5 of them for the bank1/position1 sensor..... high voltage, low voltage, slow response, no activity and faulty heater circuit.
Old Apr 11, 2006 | 04:54 PM
1996z28m6's Avatar
Re: o2 sensor miss?
in that case it is the bank1/sensor1 high voltage code...thats the only one ive seen
Z28Freak86
Apr 30, 2024 05:37 PM
markzzzz
May 8, 2015 09:21 AM
captcorvette
Mar 7, 2015 12:37 PM
Fatdog2
Feb 13, 2015 08:19 PM
dirtybird81
10
Jan 6, 2015 09:31 PM
