O2 Sensor location question
Old Oct 25, 2006 | 09:02 AM
Honda Hunter's Avatar
On long tube headers where should the o2's be? If you look in the pics I posted below youll notice it's located high. Shouldnt it be at the bottom where all the tubes come together?
Old Oct 25, 2006 | 09:06 AM
2000GTP's Avatar
On my Pacesetters, they are located towards the end of the collector. It seems unusual that they would have an O2 bung right on one tube only. You can always buy a couple of 02 bungs, drill out the correct size hole, weld in the bungs, and call it a day.
Old Oct 25, 2006 | 09:07 AM
I have this funny feeling that this is the entire reason my car is running like crap.
Old Oct 25, 2006 | 10:49 AM
evilundisguised's Avatar
Having the sensor way up there assumes that the one cylinder is representativ of that whole bank. Differences in airflow per port, fuelflow per injector, misfires, etc could introduce some error, but I don't know if it's an appreciable amount in reality.
I'd probably do what 2000GTP suggested.
Old Oct 25, 2006 | 01:29 PM
sssalah's Avatar
One wire sensors (unheated) have to be placed the same distance as stock. The further downstream its placed, the colder it will get and the reading will be differrent. This should not be an issue with heated sensors.
Old Oct 25, 2006 | 01:45 PM
jeffs383's Avatar
ya, it should be in the collector,
Old Oct 25, 2006 | 02:55 PM
HardcoreRM125's Avatar
sssalah ~ The computer will adjust for that through the BLM's
I would rather have it down at the collector, that way if you DO have a problem with one, two, or three, of the other cylinders on that bank, the sensor will read accordingly.
I would grind them off, weld it shut, and drill & weld new bungs on to the bottom.
What brand headers are those? They look like they have decent welds/flanges etc. but that is just dumb with the O2's there. I wouldnt trust it.
oldschool
Feb 9, 2016 09:21 PM
Chet1185
Parts Wanted
Mar 15, 2015 04:29 PM
AlaskaZ28
Dec 10, 2014 02:39 PM
AlaskaZ28
Dec 10, 2014 02:37 PM
ChrisFrez
Dec 7, 2014 06:01 PM
