o2 sensor location and LTs
Old Apr 25, 2004 | 10:31 PM
CamaroSS30thAnn's Avatar
does it matter whether the rear O2s for OBDll cars are in front or behind the cats?? or alls they have to be is hooked up??.....also will i need a computer reprogram for Longtubed headers?
Old Apr 26, 2004 | 08:48 AM
EviLBoX's Avatar
From the factory the rear O2 sensors go behind the cats, they monitor whether or not the cats are doing what they're suppose to. So they wouldn't do much good in front of the cats.
If you're getting long tube headers, you more than likely won't use the rear O2 sensors (especially if you're running w/out cats), in that case just get a set of O2 simulators. They just plug into the old rear O2 sensor harnesses. Or you can program out the rear O2 sensors, then you would just leave the rear O2 sensors unplugged.
Old Apr 26, 2004 | 11:32 AM
Red96Lt1's Avatar
O2 sims are about $100. A tune from madz28 is $125 plus 20 HP. I would to the tune to eliminate them. Plus he can tune out the EGR and AIR that you are probably going to remove anyway.
Old Apr 26, 2004 | 12:26 PM
Actually im keeping EGR and AIR fro emmissions purpose.......i am fabing a catted y-pipe and if i get the O2 sims i can still pass emissions??? withthe o2 sims that is ? i can use sims with catts also for the rear?
i can get around visual inspections but emmissions is a hard onein my area...but i want LTs really bad so im willing to take a risk while keepng all emmisions hookups
Old Apr 26, 2004 | 04:39 PM
EviLBoX's Avatar
Originally posted by CamaroSS30thAnn
... if i get the O2 sims i can still pass emissions???
You should still be able to pass with O2 sims, they won't effect how your car will run.
Old Apr 26, 2004 | 05:17 PM
thank you......quick question
im thinking of getting pacesetter long tubes and i want a catted y-pipe.....would it be cheaper to fab a y-pipe or just buy an ORY and two high flow converters and cut and weld?
Old Apr 27, 2004 | 08:40 AM
EviLBoX's Avatar
That depends on how much a local shop would charge. I'd get some estimates first, then decide which is cheaper. Chances are buying the cats online will be the cheaper than at the shop though.
Old Apr 27, 2004 | 08:31 PM
thanks man ,........
do i really need a LT4 knock module when i get LT headers
if i do where can i get one?
Old Apr 28, 2004 | 01:01 AM
Brent94Z's Avatar
Super Moderator
You won't know until you get the headers and install them and THEN scan the car to see if you have knock retard. After that, a simple test with race fuel 'should' be performed to see if the knock retard is real or false. THEN, after all that and determining that the knock retard is false is when you'll know that you might benefit from an LT4 knock module
maybe2fast
Mar 16, 2015 11:59 AM
Chet1185
Parts Wanted
Mar 15, 2015 04:29 PM
bsmith
Jul 19, 2002 06:08 PM
jgkinsofla
Jul 18, 2002 11:06 AM
