O2 sensor extension help.
Old Mar 26, 2006 | 11:04 PM
96ZCamaro's Avatar
Question O2 sensor extension help.
Ok, well I bought the square 4 pin 12'' extensions thinking they would work. But it looks like the front O2 sensors are wide 4 pin connectors. Is this right? I am deleteing the rear O2's so I dont think these extensions are going to do me any good. Where in the world can I find the right extensions If I do need different ones.
Old Mar 27, 2006 | 09:07 AM
EviLBoX's Avatar
Re: O2 sensor extension help.
You do need the flat 4 pin extensions for your front O2 sensors, I got mine from Thunder Racing (Scroll down)
Old Mar 27, 2006 | 11:16 PM
96ZCamaro's Avatar
How fast is they're shipping, and I will only need 12'' ones correct?
Old Mar 27, 2006 | 11:17 PM
96ZCamaro's Avatar
Oh, and forgot to mention, I will need 2 extensions right? So I am guessing it'll cost me another 50$
Old Mar 28, 2006 | 05:33 AM
2000GTP's Avatar
Yeah, you'll need two extensions, so another fifty bucks.
Old Mar 28, 2006 | 06:55 AM
96ZCamaro's Avatar
alright, thanks
Old Mar 28, 2006 | 11:32 AM
ttop1986's Avatar
you may want to get the 24 inch ones so that way you can route it nicely. The 12 inch ones may be cutting it close.
Old Mar 28, 2006 | 04:04 PM
2000GTP's Avatar
I actually started off with the 24" harnesses and they were excessively long, I then switched to the 12"s and they worked out alot better.
Victor Lamb
Aug 26, 2017 02:52 PM
Fastbird93
May 22, 2015 08:28 PM
grabbem88
Apr 16, 2015 06:57 PM
bee20e
Parts Wanted
Nov 27, 2014 05:20 PM
