o rings on the optispark
Old Jun 12, 2005 | 06:04 PM
sw89lt1's Avatar
what are they for?
Old Jun 12, 2005 | 06:12 PM
chuckd4more's Avatar
Re: o rings on the optispark
If I'm not mistaken, it's for sealing the driveshaff that protrudes through the pump housing
Old Jun 12, 2005 | 06:40 PM
Fastbird93's Avatar
they're oil seals. You WILL leak if you choose to run without them.
Old Jun 12, 2005 | 08:24 PM
They are not oil seals. The opti drive shaft has a hole in the end and there is another hole on the shaft on the other side of the o-rings. Oil is able to go right past the o-rings through that channel if it wanted to. That pretty much negates the o-rings being any kind of a seal. They appear to be there for stabilization of the shaft in the end of the cam.
Old Jun 12, 2005 | 10:10 PM
sw89lt1's Avatar
they were so dried out and brittle that i didn't realize they were o rings until i had already put it back together and found them in my gasket kit.
Old Jun 12, 2005 | 10:17 PM
A lot of times they will already be disintegrated and gone.
Jeff1904
Jun 5, 2016 05:00 PM
magman
Apr 15, 2016 03:08 AM
PopoFormula
Oct 12, 2015 04:19 PM
football4life
Oct 4, 2015 07:48 AM
colts0455
Sep 27, 2015 01:07 PM
