NYS Inspection w/ PCM4less
Old Jan 13, 2006 | 02:26 PM
markpaul's Avatar
Cool NYS Inspection w/ PCM4less
The new NY State ispection for 96 and up cars is not that bad. I have a cam, headwork, gutted cat, loud exhaust, and so on down the list(97 camaro Z28). All they do now is plug you in and scan the PCM for codes with the best part being no emissions testing...no codes = pass!
Old Jan 13, 2006 | 02:32 PM
87turbo2's Avatar
Re: NYS Inspection w/ PCM4less
Good to know since I'm going to be moving to upstate NY soon.
Old Jan 13, 2006 | 04:21 PM
2000GTP's Avatar
Same here in IL, basically you can run long tubes, no cats., a big cam, aggressive heads, so forth and so on... as long as you don't post a code, you are good to go.
Old Jan 13, 2006 | 04:23 PM
87turbo2's Avatar
Here in Duval county Fl, they do NOTHING! Just pay for your new sticker and go on your way
Old Jan 13, 2006 | 05:30 PM
Mikes 1994 z28's Avatar
Im so glad I live in Minnesota... the land of no testing.
Old Jan 13, 2006 | 05:36 PM
corbraeater's Avatar
Unhappy Re: NYS Inspection w/ PCM4less
I hate CAL i read all the time about guys running LT and big cams, i can only wish
Old Mar 14, 2006 | 09:47 PM
steves97z28's Avatar
do they look at the readiness of the systems like they do here in MA? if so did then the pcm4less tune should work for me also
Old Mar 14, 2006 | 10:44 PM
Cmr0z28's Avatar
I have no emissions.
Old Mar 15, 2006 | 03:55 AM
Buttercup's Avatar
Not entirely true. You need to have no test failures BUT you also need test completion.
This can be a problem for guys disabling the misfire test for large cams, disabling cat monitoring O2 sensors, etc., etc. While they aren't throwing codes, the tests also show up as not completing. Some of these tests must complete with a pass or you don't
Luckily I don't have to worry about this emissions testing junk... though I'm sure my car would pass or I would make sure it did
ducttape1975
Classic Engine Tech
Mar 26, 2016 04:17 PM
karpetcm
Sep 29, 2015 10:08 AM
scottcba1
Sep 8, 2015 09:52 AM
88IROC_Z
Jul 22, 2015 11:38 PM
ducttape1975
Jul 10, 2015 06:29 PM
