Nur2s
Old Jan 27, 2010 | 01:40 PM
NUR2S's Avatar
Nur2s
1994 z28 has service eng. Fault-scan indicates leaning out on left bank (driver's side)-any ideas on remedy for fault?
Old Jan 27, 2010 | 02:17 PM
Please post the exact trouble code when you are asking about them (and please put something meaningful in the subject line). You might have a bad O2 sensor, O2 wiring problem or even an exhaust leak.
Old Jan 27, 2010 | 03:10 PM
Or.... it might actually be running lean due to low fuel pressure, incorrect injectors/programming, faulty MAF sensor, large leak in the elbow between the MAF sensor and the throttle body, massive vacuum leak, etc.
