now what????
Re: now what????
Where at on the head? If you can get an angle drill in there, then I would suggest Helicoil. You end up drilling out the broken bolt, thread the hole and screw in the insert. It's a lot easier than it sounds. If you have to, break the engine loose to give yourself more room.
I just did the same thing on my Silverado about a month ago.
Re: now what????
Originally Posted by Z95m6
Which header bolt is it? If its the very first or very last bolt on either side you don't need them.
How the F*** am i going to get that out???
