now i have a no start condition
so i was working on diagnosing the ignition system following these procedures
Diagnose The Optispark - LS1LT1 Forum : LT1, LS1, Camaro, Firebird, Trans Am, Engine Tech Forums
everything had checked out, i did clean up the engine block to body ground, i had the signal from the white wire on the ICM lead and the signal on the coil side along with 12 volts going to both the coil and the ICM. i put it back together and tried to start the car. it ran for a second and quit.
now i checked for fuel. i do not have a pressure gauge so i had to use the "scientific method". i pushed down on the pressure test stem and only got a little dribble, i should have had gas spraying out. i think the fuel pump is toast and it has been going on its way out for a while, the car has been progressively getting worse.
so i guess i have to do a fuel pump now. is their any tests i can do on that circuit? how difficult is fuel pump removal from a 4th gen? is it as bad or worse then a 3rd gen, i have done a couple of those in my time and they sucked. the biggest pain is not having a rubber hose to disconnect the fill tube from the tank. not fun
also should i get a pump from autozone or should i go with something from summit or jegs?
could a failing fuel pump be causing all of my issues all along? it could cause a mis-fire, rough operation, and hesitation?
Re: now i have a no start condition
the code was still active. i cleared the codes, car still will not start. it sounds like i can hear the fuel pump turn on but i still do not appear to have any gas at the test port. i wish i had a pressure gauge so i could be more accurate in my findings but when you push down on the valve stem you should get a solid spray of gas. all i get is i hear some air escaping, either that or my fuel gauge is lying. it says i have 1/4 tank, and the car has ran with less then 1/4 tank before. i think i will add a little gas tomorrow and see if it makes any difference....... i do not want too much gas in that tank if i end up pulling the tank, the more gas in the tank the worse the job will be.
i also do not understand why it was setting code 1371 if i was getting signal, ground, and power on both the ICM AND the coil.
actually my next step was to just remove and check the fuel filter, that might the answer and if its plugged $5 will replace it. if its not plugged then off i go to get a fuel pressure gauge.
