not sure...spark plug?
Old Jul 24, 2008 | 09:53 PM
mikemassi's Avatar
im not sure wat could cause this, but today i got gas and about 5 min after my car started to stumble wen accelerating and it looses all its power and shakes and stumbles wen i hit the gas. but if i manually shift the car down to second and its at like 3500 rmps it kinda goes away? anyone know what this could be... mabye bad gas, spark plugs, opti? (94 z28 automatic)
Old Jul 24, 2008 | 10:14 PM
Jazsun's Avatar
all signs point to bad gas..probably water in the gas. buy a bottle of heat and put it in the tank should fix the problem.
Old Jul 24, 2008 | 10:23 PM
mikemassi's Avatar
what do u mean bottle of heat?
Old Jul 25, 2008 | 03:29 PM
Granite00's Avatar
"Heat" is fuel additive that you put into the gas tank. If there is water in the tank, it allows it to mix with the gas and be burned. They sell it in the cold climates to keep fuel lines from freezing. It also goes by the name gas antifreeze.
KYWes
Jun 14, 2022 06:52 AM
sherwinZ28
11
Aug 15, 2015 05:38 PM
350350
14
Aug 11, 2015 12:03 PM
zajones
Jul 30, 2015 02:18 PM
Xiantyl
Jul 21, 2015 05:42 AM
