Not sure if it's my opti.
Old Dec 27, 2005 | 10:03 AM
Manco's Avatar
I've got a '95 M6. The symptoms: If I gas it in the lower RPMS the car bucks. For example, Cruise control set on the interstate, going up hills the car bucks intermittently, about once or twice a second. Car pulls fine through the midrange, once it hits higher RPMS is maintains RPMS fine but something is definetly wrong and I'm pretty sure it's missing.
So far I've thought this was my opti, BUT the more I've been reading on here the less I'm sure. The car does this at all times, whether it's hot or cold. The opti has already been replaced, like less than 10k miles ago by previous owner. No hard starting issues, does not seem to idle rough.
Could this be my coil? Does this sound indiciative of 02 sensor? I don't want to spend the $ on an opti if that's not the case. TIA.
Old Dec 27, 2005 | 10:05 AM
wrd1972's Avatar
Re: Not sure if it's my opti.
Yup, it feels like the engine is surging a bit.
Mine did the exact same thing and I replaced the plug wires and now the problem is gone.
T the time I had new OEM wires installed and I now have Elite OVC 9MM plug wires.
Old Dec 27, 2005 | 10:14 AM
Manco's Avatar
I should also add that when going through the upper RPMS it does occasionally skip a beat (obvious miss). Doesn't always do this. Doesn't seem to be at the same RPM each time either.
Supposedly the wires and plugs were changed at the same time or later as well. The car was supposed to have a tuneup shortly before I bought it (less than 10k miles ago)
It started this behavior shortly after I took it to the track (7 ***** to the wall passes within 2 hours)
Old Dec 30, 2005 | 04:52 PM
madtytefbody's Avatar
Check ur Spark plugs and wires... i am having the same exact problem and my mechanic told me that its my plugs and this isnt the first time this happen...this is the cheaper option to go, if it still persists then it can be ur opti but i would do plugs and wires first
drew
Old Dec 30, 2005 | 04:54 PM
blkchevyz's Avatar
like most people say, pop the hood when its dark out, look around the plugs and wires and see its arking or glowing around any of them
also check your coil wire.
Formula Steve
Sep 19, 2023 08:31 AM
reww86
Aug 29, 2015 06:04 PM
9t4lt4z28
Jun 21, 2015 08:18 PM
kevkop94TA
May 4, 2003 07:39 PM
94droptopz
Apr 28, 2003 08:15 PM
