Not starting when hot
Old Jul 19, 2006 | 01:14 AM
jj93z28's Avatar
Basically if you drive the car for even a brief time and then turn it off, it wont start until it cools off. I would say it takes around 30mins to an hour. When it does start it runs fine with no issues, until you shut it down. I was thinking the coolant temp sensor in the waterpump or a leaky injector.
Anyone have a similar problem, or any suggestions.
Old Jul 19, 2006 | 08:02 AM
Re: Not starting when hot
Define "won't start"? Is the problem the starter won't turn the engine, or is it when the starter turns the engine the engine doesn't start?
Old Jul 19, 2006 | 09:23 AM
fastchevy's Avatar
Depending on what it's doing it sounds like the starter is getting heat soaked. Time for a new one.
Old Jul 19, 2006 | 09:26 AM
StephenDeli22's Avatar
ICM could be getting heatsoaked too
Old Jul 19, 2006 | 02:58 PM
jj93z28's Avatar
The starter turns the engine over without an issue. The car just doesn't start. If you leave it for a minute it might start for a few seconds then die. The longer I leave it to cool down the longer it seems to run.
Old Jul 19, 2006 | 06:56 PM
JJJ93z's Avatar
i 2nd that, starters are relatively inexpensive, how many miles on the orig one?
Old Jul 20, 2006 | 12:51 AM
jj93z28's Avatar
As I said above the starter turns the engine without a problem. Again the starter is not the issue. Thanks though
Old Jul 20, 2006 | 05:14 AM
Guest47904's Avatar
Guest
You mention an issue when restarting but what happens when you don't shut it down? As in an extended drive. Do you notice any poor running or misfiring?
Perhaps you could monitor fuel pressure when you go to restart it or pull a plug wire and check for spark.
Old Jul 20, 2006 | 09:18 AM
fastchevy's Avatar
Ah, OK..if that was stated first I would have said the ICM...I also said depending on what it's doing though..
Old Jul 20, 2006 | 12:02 PM
Sweetred95ta's Avatar
If it was the ICM, wouldn't the car faulter while it was running?
Old Jul 21, 2006 | 11:58 PM
jj93z28's Avatar
If you just continue to drive it is ok, I noticed the idle gets a little choppy but no misfire. I was thinking the same about the fuel pressure.
I may have solved my problem. Today it wouldn't start again, in the process of trying a few things I dissconnected the tps sensor and the car fired on the second try. So I picked up a new tps, I notice the idle isn't as choppy and the car tends to fire better. Since the problem is so sparatic it's hard to say if that was it.
meissen
Jun 1, 2015 07:59 AM
mspennyhughes
Mar 1, 2015 03:50 PM
Britbilly
Jan 7, 2015 08:49 PM
Caps94ZODG
22
Jul 30, 2002 08:45 AM
