not LT1 but need help Quick. Broke Balancer/crank pulley bolt.
Old Jul 27, 2009 | 01:20 AM
95silver3.4's Avatar
Exclamation not LT1 but need help Quick. Broke Balancer/crank pulley bolt.
Hey, new to forum but need help.
Had crank sensor go bad, replaced myself to save $. On 3.4l, behind harmonic balancer+pulley. Rented Pulley puller & installer tools from Autozone. Sucessfully removed pulley, replaced sensor, and began to use installer to press balancer back on. It basically has a threaded screw the same size as main/center pulley bolt and screws into hole while you toque down larger screw/bolt combo that fits over it. We'll i was 75-90% finished pressing balancer back on and it snapped off in hole, the screw/tap.:judge::bash:.
It has a center hollow shaft inside the screw that broke of so easy to tap/start threading with extractor tool. But heres my question.
Original quote to replace sensor was $250, so I thought I could do it for $30(price of sensor). Now that I'm fked, how much for them to use a broken bolt extractor bit to back it out and re-press on the balancer??? My original bolt is still intact, just the pulley installer tool screw/starter bolt is broken off in main hole of crank. Could I attempt this myself by buying a $5-15 extractor tap kit and drill it out? Or save the hass
Old Jul 27, 2009 | 05:21 AM
You've already got this posted on the V6 Tech forum and the "General......Tech" forum. No need to post it a 3rd time here.
SpeedJunkee
Jan 27, 2015 10:02 PM
Jason Short
Jan 19, 2015 06:34 PM
ddr698
Jan 9, 2015 10:05 AM
1LEThumper
Jul 14, 2003 12:45 PM
