not an LT1 but i need help
Old Feb 16, 2004 | 05:12 PM
BadAssed93Z's Avatar
my beater is crapping out on me bad.
when driving i let out of the clutch and step in to the gas and it goes, but as soon as the clutch is out if you dont keep the rpms up around 4k it tries to bog and die, once your up to speed its ok but trying to get going it looks like i cant drive, it just jerks and jerks like the worst stall youve ever seen. imagine the first time you ever tried to drive stiuck and it was little jerky, now multiply that times 1,000,000,000,000. its bad. and the camaro isnt done yet.
any thoughts as to what this could be,
even when you let off the clutch completly it likes to jerk and try to bog. it seriously looks like im the worst driver in the world and i wasnt until this started to happen.
thanks alot.
edit: my beater is a 1988 mazda 626, five speed, 2.2l
Old Feb 16, 2004 | 05:23 PM
Robs97Z28's Avatar
when was the last time you did a tune up?
Old Feb 16, 2004 | 05:26 PM
it got new plugs and wires about a year ago
but the car idles fine, well as good as it always did.
its jyust when you try and drive it.
Old Feb 16, 2004 | 05:36 PM
mullettour's Avatar
If you have the accelerator to the floor with it in neutral does it rev easily or bog? If it bogs its a possible fuel filter or injector.
Old Feb 16, 2004 | 05:39 PM
Robs97Z28's Avatar
it is also possible the coil is going out. The coil has to put out higher voltage under a load. I would check all three things, fuel filter, coil, and fuel pressure.
Old Feb 16, 2004 | 05:49 PM
thanks for the suggestions guys ill make sure i check those out,
thanks a lot
any other ideas
Old Feb 16, 2004 | 05:52 PM
SROKED30TH
Guest
Posts: n/a
Does it rev in neutral like a normal car would ?
Old Feb 16, 2004 | 06:00 PM
yeah it revs in neutral
oldschool
Feb 9, 2016 09:21 PM
DirtyDaveW
Mar 15, 2015 07:01 PM
Noer
Feb 28, 2015 11:29 AM
InfernalVortex
Jan 17, 2015 09:35 AM
Hot Rod Hawk
Aug 30, 2002 10:12 PM
