Not head gaskets cracked head Help please
Old Oct 3, 2008 | 06:35 PM
94 Sunburst formula's Avatar
I thought i blew a head gasket nope cracked head in the exh port Must have been over ported. Can these be welded up or is it just better to buy a head? If anyone has a 374 passenger side head for sale sent me a pm.
Old Oct 5, 2008 | 09:48 PM
77amc's Avatar
Maybe ask the shop that ported it..?
You might place your finger down the port of each in the same position.
If it warms up kinda quickly by touch you maybe paper thin.
Or if it's a good shop, they should have a sonic tester like for cyl walls..
Just my .02
E
Old Oct 6, 2008 | 04:13 PM
I did them myself I almst looks like there was an air bubble there from when it was cast. Its an almost perfect pen size hole. Its at a machine shop getting welded up rite now.
Old Oct 6, 2008 | 07:52 PM
MTBSully's Avatar
hmm didnt know you could weld a head and fix it. let us know how it turs out. I assume you had to remove the head from the car?
Old Oct 14, 2008 | 04:05 PM
Well got the head back from the machine shop and got it together. The hole was in the exh port, on the top side. Yes heads were removed. I got about 200 miles on it since the fix and will be going to Muncie tomarrow to race it, so i'd say it worked.(at least so far)
Old Oct 14, 2008 | 08:31 PM
MachinistOne's Avatar
Fixing aluminum heads is easy and very common. Cast iron is more difficult and expensive.
Chris Anderson
Jan 27, 2015 08:30 AM
HectorM52
Parts Wanted
Jan 10, 2015 09:01 PM
Jazsun
Dec 29, 2014 12:14 PM
thenewkid
Nov 27, 2014 09:41 AM
