Not firing somewhere?
Old Dec 7, 2007 | 11:46 PM
x24-7x's Avatar
Ok im new here so hi everyone.ha. Anyways, i did some searching and couldnt find much of an answer. My problem is- i have a 95 firebird and it was missing pretty bad. Well i decided to just get on it, and when i did, it cut off, and wont start back. My ICM is ok because i took it off and put it on a buddys car and it fired right up. There is no spark goin from the coil to the distributor. I replaced the coil and still, same problem. Any ideas? Or ways to check anything else?
Old Dec 8, 2007 | 10:45 AM
Its possible you lost the rotor or the optical sensor in the Optispark distributor. Have you scanned it for codes? Is the SES light on?
Old Dec 8, 2007 | 12:37 PM
x24-7x's Avatar
Well my SES stays on because of no air pump or egr. Im in the process of taking off the water pump, etc. so i can get to the distributor. I checked most of the wires goin to the PCM and didnt see any fried or anything...
Old Dec 9, 2007 | 10:35 AM
x24-7x's Avatar
Found the problem. My rotor button broke. Appreciate the help Injuneer
Old Dec 9, 2007 | 10:56 AM
Why not eliminate the SES light for the AIR and EGR so the light will serve a useful purpose. For the OBD-I cars, the AIR pump can be unplugged and eliminated, and will not turn on the SES light, as long as there is a good fuse in the circuit. For the EGR, if you subsitute a resistor for the EGR vacuum solenoid, it will definitely eliminate one of the EGR codes, and generally the other code for low flow will not set in about 75% of the OBD-I engines. Or have the systems "programmed out" of the PCM.
Jeff1904
Jun 5, 2016 05:00 PM
PopoFormula
Oct 12, 2015 04:19 PM
Ks0209
Oct 1, 2015 07:32 AM
KYWes
Sep 26, 2015 08:49 AM
Ryan Ramsaran
Sep 19, 2015 08:43 PM
