Not drivable. Need suggestions.
Old May 7, 2005 | 03:15 PM
MarineReconZ28's Avatar
My 95 Z was down for a few days while I pulled the heads off for a blown gasket, and when I put it back together I have had nothing but problems. It idles real rough and it dies when I come to a stop unless I put it in neutral or park. It runs ok when I ease in to the throttle except there is a bad vibration/shake at 1500rpm in any gear. And it's sluggish if I step on it hard.
I don't know if I overtightend a rocker, or if I have a vac leak and something else, or if there's a bad sensor somwhere.
I did everything myself, and it was my first time pulling the camaro apart that far. So my chance of error was pretty high on the re-assemble. Any suggestions would help.
Old May 7, 2005 | 03:18 PM
Dave89IROC's Avatar
Re: Not drivable. Need suggestions.
I think you should readjust the rockers, I like doing it with the engine running
Old May 7, 2005 | 05:20 PM
dkeers's Avatar
You may have got the O2 sensors wet whent the head gasket blew. Hook up a scan tool and you will be able to tell if you have lazy (or dead) o2 sensors.
Old May 8, 2005 | 11:23 AM
I'm going to try to get it scanned within the next few days. Dave, I don't know if I'm brave enough to try anythimg like that with the engine running. I'll leave that to you ASE Certified Master Technicians for now. I like to do things the way my Helms manual tells me to, and nothing different. I trust it, it is my friend. But I will go back and redo it to see if that helps.
68camaroboltz
Oct 5, 2015 01:46 PM
thenewkid
Apr 12, 2015 07:42 PM
A's 91 Z28
Jan 11, 2015 10:58 AM
92ragtop
Dec 27, 2014 01:56 PM
KLUCKS-SS
Mar 1, 2003 11:46 PM
