Normal/Safe engine temp?
Old May 24, 2004 | 05:56 PM
warwickbass's Avatar
Anotherwards, when everything is working properly about what temp should my '95 LT1 be at? Thanks.
Old May 24, 2004 | 06:15 PM
A stock car, cruising along the highway, 180° thermostat, will be ~190°-195°. When you sit in traffic, the engine heats up because there is no air flow across the radiator. The stock fans will come on at 226°.
Old May 24, 2004 | 06:19 PM
Well, here recently, after awhile, it'll get close to 260. I have no idea what the problem is. How could I check to see if it's the waterpump?
Old May 24, 2004 | 06:54 PM
1msfyter's Avatar
Check all the hoses for leaks, look under the waterpump at the weephole. Pressure check the cap. Drain and re fill with new water and anti freeze, add a bottle of waterwetter, that helps keep the temps down. Also dont forget to drain and clean the overflow bottle(lot of brown crap in there)
Old May 24, 2004 | 09:43 PM
Check the front of your condensor for a Wal-Mart bag or the daily newspaper. Sometimes there can even be debris wedged in between the a/c condenser and the radiator.
cmdeshon
Dec 27, 2014 10:06 AM
jayblev95
Dec 1, 2014 06:55 AM
Jul 4, 2005 05:00 PM
Cam28_boy
Aug 6, 2002 08:40 AM
Darth Xed
13
Jul 22, 2002 12:45 PM
