Normal/Safe engine temp?
A stock car, cruising along the highway, 180° thermostat, will be ~190°-195°. When you sit in traffic, the engine heats up because there is no air flow across the radiator. The stock fans will come on at 226°.
Check all the hoses for leaks, look under the waterpump at the weephole. Pressure check the cap. Drain and re fill with new water and anti freeze, add a bottle of waterwetter, that helps keep the temps down. Also dont forget to drain and clean the overflow bottle(lot of brown crap in there)
Jul 4, 2005 05:00 PM
Darth Xed
13
Jul 22, 2002 12:45 PM
Sometimes there can even be debris wedged in between the a/c condenser and the radiator.
