Normal Operating Temperatures?
Old Dec 29, 2009 | 03:03 AM
NewbieWar's Avatar
So, always struggling with keeping my LT1 cool enough, I am concerned why my LT4 is always so cold...
A few things to start off...
LT1 ran in Los Angeles, (average outside temp 80* 1200 feet elevation)
LT4 currently running Germany (average outside temp 20* 800 feet elevation)
LT1 had eddlebrock headers w/ cats
LT4 still running manifolds w/o cats
LT1 always ran about 220+ once it was warm (with 160 thermo)
LT4 seems to run about 165 once it is warm(not sure, but probably 160)
LT1 had heater core removed
LT4 heater core reduces fan pressure because temperature is low(give me a break its 20*).
I know the outside temp changes things dramatically, but is the engine temp something I should be concerned with?
Also
LT1 A4
LT4 M6
Old Dec 29, 2009 | 03:53 AM
MikeGyver's Avatar
Operating temperature is not just determined by the thermostat, the cooling system is very reliant on the fans.
If you use a 160* thermostat, they fan settings much be rescaled (the same same percentage) or the car will basically run at the same temp.
Old Dec 29, 2009 | 08:47 AM
NewbieWar's Avatar
but shouldnt the engine still run around 180*?
Old Dec 29, 2009 | 08:50 AM
If you don't know the rating of the t'stat, do you even know if there is one installed?
Are you reading the coolant temp off the dash gauge, or off the PCM?
What does "LT4 heater core reduces fan pressure because temperature is low" mean?
Old Dec 29, 2009 | 08:53 AM
NewbieWar's Avatar
I dont know if there is even one in there,
I do know however, my LT1 did not have one installed when I had purchased that car, and it took forever to warm up...
I am using the dash gauge, will have my tuner in a few days, so will have better info.
I dont know if it is normal, but when I turn the air from cold/hot, the pressure is reduced, and as the engine warms up it gets stronger(I think, either way its still much slower than if the air is set to neutral or cold)
Old Dec 29, 2009 | 11:15 AM
bw_hunter's Avatar
The airflow at the outlets is reduced because the airflow is directed through the heater core. It has nothing to do with the temperature of the coolant or the temperature of the outside air, only where you have the HVAC temp **** set.
Old Dec 29, 2009 | 11:18 AM
RUDEDOG's Avatar
I have a 160* stat and no fan reprogramming and temp stays at 175*. Fans never run unless I use ac.
Old Dec 29, 2009 | 11:21 AM
NewbieWar's Avatar
thanks, bw_hunter
What temperature is ideal for the engine?
Old Dec 29, 2009 | 07:09 PM
Z-RATED94's Avatar
I have no idea what the ideal temp would be, but I'd be concerned if it wasn't at least 170 once up to running temp.
Old Dec 29, 2009 | 07:14 PM
thanks, bw_hunter
I'd say 180-200 during cruising.
truecontr3
Oct 11, 2015 09:30 AM
95z_28_camaro_4_Ivan
Oct 3, 2015 07:27 PM
Hal Fisher
Sep 30, 2015 09:03 PM
SEOJustin
Sep 24, 2015 04:39 PM
damnyankee36
Sep 9, 2015 07:06 PM
