IS THIS NORMAL(Oil Pressure)
Old Jul 15, 2004 | 12:12 PM
  #16
GetaZforgetGT's Avatar
Your pushrods must have looked like oil derricks to loose two quarts of oil while adjusting your rockers.
Old Jul 15, 2004 | 12:25 PM
  #17
LT1CST's Avatar
Yeah I guess. Well my last motor. that I had. MY DUmb Self Neglected To HOT tank the BLOCK. SO it wasnt manking NO OIL PRESSURE at all. So now I got it hot tanked and evertying its making OIl pressure and I do the rockers now and oil gets all over the Friggin place. IT was bad.
Chris
Old Jul 15, 2004 | 01:26 PM
  #18
WS Sick's Avatar
Originally posted by izzyz28
I really need the Part #'s for both the windage tray and the studs. I am assuming you are still running the stock pan, but if you aren't, can you get me the part number for your pan too. By the way, did you have to do any adjusting/trimming of anything to get the windage tray to fit?
Thanks in advance !
I ordered the studs and tray from Jegs they are milodon peices, I had to do a little clearancing for the longer stroke of the crank, but my stock pan fit right over it all.
Milodon diamond stripper windage tray....697-32250 74.99
Milodon tray installation studs (kit)...........697-81150 42.99
These are the part #s that Jegs uses for them.
The pump was a factory GM replacement bought from a Chevy dealer (he had a few overstock and let me have it dirt cheap.)
But I used the stock pick-up welded on and a white Z-28 spring.
Old Jul 15, 2004 | 03:54 PM
  #19
izzyz28's Avatar
Thanks a ton WS Sick! I'll order the stuff in the next week. You've been very helpful. One last question: Does your oil pump use the big 3/4" pickup tube or the smaller "normal" size 5/8" tube. Just curious.
Old Jul 15, 2004 | 04:03 PM
  #20
WS Sick's Avatar
My stock pump and the replacement I bought at the chevy house both had the bigger tubes.
HectorM52
Jul 30, 2017 11:46 AM
KYWes
Apr 15, 2015 05:48 AM
ad356
Apr 11, 2015 08:49 AM
transam_388
Mar 15, 2015 11:53 AM
jayblev95
Dec 1, 2014 06:55 AM
