Is it normal to be able to wiggle the pistons in the bores?
Old Mar 16, 2007 | 04:01 PM
speed_demon24's Avatar
I was just wondering if its normal to be able to wiggle the pistons around in the bores a little bit. They are extreemly lose or anything, but I can move them side-side a hair.
Old Mar 16, 2007 | 05:11 PM
foggedz's Avatar
Should be normal.
Old Mar 16, 2007 | 06:09 PM
fbodyboy's Avatar
yes thats normal, max movement aloud stock is .032 of an inch. wich will cause some wobble.
Old Mar 16, 2007 | 06:11 PM
SS MPSTR's Avatar
did you check piston to bore clearance?
Old Mar 17, 2007 | 11:41 AM
Explodinggopher's Avatar
isn't it normal for LT1s to have some piston slap?
Old Mar 17, 2007 | 12:10 PM
96 mikez28's Avatar
If your pistons are slapping the valves you have a problem
Old Mar 17, 2007 | 12:33 PM
SStrokerAce's Avatar
Stock pistons?
Old Mar 17, 2007 | 12:38 PM
LiENUS's Avatar
Piston slap has nothing at all to do with the valves. It has to do with the piston rocking in the bores. It sounds like a knock on startup but goes away as heat expands things, my car makes it sounds similar to an exhaust leak but if you head an exhaust leak then immediately heard piston slap you'd notice the difference.
Old Mar 17, 2007 | 02:51 PM
matLT1's Avatar
I think it would be a good idea to check the clearance while you have access.
Old Mar 17, 2007 | 03:43 PM
chevytuned's Avatar
Yes pistons are not round. they are bigger at the bottom of the piston. depending on the type of piston should be about .002 to .004 forged pistons should be .002 cast is about .004 thousands clearance. Jason
Old Mar 17, 2007 | 03:54 PM
Chevycobb's Avatar
yeah piston slap is nothing to usually worry about. stock LS1's have had that problem I think, but the piston will expand with heat and it will go away.
dont forged pistons usually have piston slap??
Old Mar 17, 2007 | 04:10 PM
chevytuned's Avatar
forged pistons have a ring to them that could set off the knock sensor depending on how loud it gets. The piston slap came along with the newer motors its not a problem I have the ls motor in my truck its worse in the winter I think it had to do with the location of the rod being further up the piston but not real shore.
Old Mar 17, 2007 | 04:35 PM
Originally Posted by SStrokerAce
Stock pistons?
Yep.
Old Mar 18, 2007 | 06:09 PM
That might be a bit loose then.
Old Mar 18, 2007 | 07:41 PM
SS RRR's Avatar
It'd be a good idea to measure the bores while you can.
Chevy Trucks.
Like a Knock
I heard it clear as day
Like a knock
damn near blew my engine away
Like a knock
I was hoping to get my engine replaced
by the dealer but they said OH HELL NO WAY!
Like a knock....
I could go on and on.
