noob / waterpump question
Old Jun 5, 2006 | 01:42 PM
6SpdLT1Z's Avatar
Waterpumps fail and get the opti wet causing it to fail, correct? My car has 135k and I was thinking about getting a electric water pump.
Do electric water pumps give you more horsepower? ( )
A "stock" waterpump is driven off the belt right? Will I need a new serpentine belt or what?
Any tips? I found a decent deal on one and was just wondering if It'd be a good idea.
Thanks.
Old Jun 5, 2006 | 01:52 PM
user 647483's Avatar
Re: noob / waterpump question
A failed waterpump could get an opti wet, although mine drained itself through the weephole
for a good 2-3 hours all over the driveway and didn't hurt it any.
A leaking gasket will cause coolant to leak onto the opti, and that could hurt it.
You'll want to cover your opti and drain your coolant before removing the water pump.
Eletric pumps don't so much make power, but they reduce the amount of HP lost trying to run the mechanical one. They run off electricity generated by the alternator.
On an LT1, the waterpump is driven by a shaft.
No pully, so no belt change is required.
Easy install, http://www.projecttransam.com/projects9.asp
Lots of pictures, details and even dyno results.
Old Jun 5, 2006 | 01:56 PM
njenson's Avatar
From what if heard...
1. when the stock pump starts to fail it leaks through the weep hole which has a strong possibility of getting the opti wet.
2. A EWP does FREE UP more by taking the drag off the engine that is used to turn the stock pump.
3. the stock pump is run off the camshaft not the belts so no different belts are needed.
4. if the car is a daily driver you should get something to monitor the EWP to make sure the pump is on (the car will get hot really quick if the pump isnt going, therefore it will damage it fast if not noticed quickly)
Old Jun 5, 2006 | 03:49 PM
6SpdLT1Z's Avatar
Thanks, I was looking at picking up the CSR from Chrisbequick on mofbody.
What are you talking about? And it is my daily driver.
Old Jun 5, 2006 | 03:52 PM
StephenDeli22's Avatar
He is talking about if the pump fails then your motor is likely to blow a head gasket very quickly.
Old Jun 5, 2006 | 08:38 PM
6SpdLT1Z's Avatar
I know but what's he mean about monitoring it...
Old Jun 5, 2006 | 11:47 PM
1racerdude's Avatar
If ya go with an electric pump ya will have to remove the timing cover and remove the WP drive gear and plug the hole in the cover.
Old Jun 6, 2006 | 07:34 AM
njenson's Avatar
meaning getting a monitoring system to watch over the pump that will light up or sound when the pump fails or u get a burned wire, or etc...
i know there is one company that makes one or there is also an individual who makes them on the impalla ss forums
example http://impalassforum.com/noncgi/ulti...8;t=000199;p=1
his kit will be the one im getting when i do it, but i guess he only does group purchases
Sergio
Jan 27, 2016 04:27 PM
Dan_the_ManZ28
Feb 21, 2015 02:01 PM
pologreen97z
Dec 2, 2014 10:42 AM
lbrowne
Nov 13, 2011 04:25 PM
