Noob question on leaking oil pan
Old Jul 26, 2009 | 12:23 PM
95Blackhawk's Avatar
Hey all, I took off the pan and put it back on with an new gasket. But even with significant silicone when reinstalling, I am getting a slight leak at the pan/timing chain cover location.
What is the best way to fix? Gobs of silicone on the outside or something more drastic?
Thanks,
Ben
Old Jul 26, 2009 | 12:37 PM
Stl94LT1's Avatar
I've had the best results with installing a Felpro oil pan gasket dry, no silicone.
Old Jul 26, 2009 | 03:58 PM
raroz28's Avatar
The gobs of silicone is causing your leak. If the gasket is new, you should be able to drop the front of the pan and peal the gasket maker off of it without doing any damage.
That's a dirty job man, good luck with your fix. If it's still leaking after you fix it, make sure it's leaking from the pan and not somewhere else.
HectorM52
Jul 30, 2017 11:46 AM
Jessie4tin
Jan 7, 2015 08:53 AM
Queens94z28
Dec 20, 2014 09:11 PM
siguy
Nov 27, 2014 10:07 AM
Elcojoe
Nov 17, 2014 10:27 PM
