HP for my possible LT1
Old Jul 25, 2009 | 10:46 PM
rustykey's Avatar
What kind of numbers do you think this combination will make?
355ci LT1 refreshed block
Stock Crank/Rods
Forged pistons
CC306 cam
GTP stage II ported heads with a ported Lt4 intake
1.6 rockers
Stock injectors...should I upgrade?
58mm TB
Pacesetter Long Tubes
3inch YPipe
3inch to Borla open Exhaust
3:73 gears
3600yank in 4l60e
Suncoast Airbox
Is there any other bolt ons that would benefit me?
Thanks,
Rusty
Old Jul 25, 2009 | 10:58 PM
toomchz4u's Avatar
Don't know how much hp you will make but you need some more injectors. Get some 36 or 42's.
Old Jul 26, 2009 | 07:19 AM
rustykey's Avatar
I was figuring I would need some different injectors, thanks for the input.
Old Jul 26, 2009 | 07:49 PM
maddog05's Avatar
The balanced AL drive shaft will help HP at speed and quiet down the car..., chrome valve cover breather..the chrome does not help HP but free breathing frees up a pony or two...you'll need a knock sensor eliminator (resister) or LT4 set up... clean the maf screen, set RPM cut off at 6400, do all free mods - omit air pump, egr, TB warmer,...and dyno-tune it; with the new injectors... 46 lb...is way too high...should get >390 to 400 at rear wheels.
oldschool
Feb 9, 2016 09:21 PM
DirtyDaveW
Mar 15, 2015 07:01 PM
Noer
Feb 28, 2015 11:29 AM
InfernalVortex
Jan 17, 2015 09:35 AM
Hot Rod Hawk
Aug 30, 2002 10:12 PM
