Noob Question How much H.P. should my car have???????
Yes I am a noob for sure, I just bought A 94 z28 M6 it has the K&N cold air kit, Com 306 cam, Gross valve lift .510/.540 I think,Ported heads with the comp springs, Pace setter Long tube headers, Pace setter offroad Y-pipe Full 3" exhaust with a single in dual out Flowmaster, It also has a MSD Digital window switch Not sure how to use it though. Also had the PCMforless tune for the cam.
Just wondering what the H.P. Should be, I know Some of you will say just go and get it dyno tested but Im not sure where to go or if it really even matters. Also It does not have an ignition Enhancement Such as an MSD Ignition Would that help??? Im sorry But I am a Noob!!! Oh by the way it also has a 100 H.P. Shot of Wet TNT Nitrous.
Last edited by weinersnitzelz; Jun 27, 2007 at 11:04 PM. Reason: Forgot to post info
Its really hard to say unless you have some flow #s from the heads, injector size, or a handfull of others.
But I'd say anywhere from 350-430 off nitrous, depending on the dyno and how much time they put into tuning the car.
But this is just a guess, so take it for what its worth
Thanks for the reply, I bought the car about a week ago so im just tryin to learn _ About the car I live in Houston, Tx so im sure there are plenty of places to get it dyno tested, I have the papers for the com 306 cam, Im just learning about the Cams and I think the guy said it has 30 Lb injectors but thats about all I know, Does anybody know what the MSD Digital window switch does?? Thanks
It's an engagement/disengagement switch for nitrous. Do you know if it has nitrous plumbing? You are able to turn the N20 on and off at a given rpm. It's a safety mechanism used to help avoid blowing up your engine by either spraying N20 into the engine at too low or too high of a rpm.
I'm not a big fan of MTI, but they're right close to you and at least have a dyno: http://www.motorsporttech.com/contacts01.asp
You take your car there I'm sure they'll try to talk you into getting a LS1.
I dont think it has nitrous plumbing into it but I will check Thanks for the Link I drive by that area all the time
My car domain is http://www.cardomain.com/ride/2672925
Could anybody tell me what wheels those are, and I got the car for $4,000 Im not sure if it is a good deal but it seemed pretty good the car runs great.
Depends what you can tolerate. True duals will give the biggest gain, and I have no regrets getting mine. They would probably be too loud for a daily if you run them dumped, but I have mine run out theback without any compaints.
That catback is not "killing you", you could put ANY single in/out muffler on it and be fine, even a FLowmaster. ANY crossflow muffler will not flow as well as a single/in out muffler.
Use the catback you have on the car and install a single in/out Magnaflow muffler with a dump on the drivers side.
David
David
as for the exhaust, i'd suggest a cutout. i've read on here on highly modded cars a gain of 30+rwhp from a flowmaster catback.
ChrisFrez
Dec 21, 2014 09:47 PM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
ChrisFrez
Dec 15, 2014 03:09 PM
ChrisFrez
Nov 23, 2014 10:33 AM
