NOOB needing info on short block build
Old Jul 17, 2006 | 08:14 PM
snakeatinZ's Avatar
Tried to search and came up empty. What rotating assembly can I go with on a budget, to handle roughly a 200 shot. Does someone have a good write up for building a short block and are the any good books out there you know of, as far as torque specs? Is it worth it to build the motor myself to save a few $$, or should I leave it to professionals? I have done quite a few heads and cam swaps so I am ready to step up to the short block, if you think its a good idea. Thanks for your help!
Steve
Old Jul 17, 2006 | 09:35 PM
snakeatinZ's Avatar
Re: NOOB needing info on short block build
Just found a post on power that a stock short block can take. I will rebuild it with a stock crank, stock rods and srp pistons, good rings and turn the block it to a 4 bolt main block. That aside all I need now is pointers on building the short block, ie special tools, and a write up on this subject.
Old Jul 18, 2006 | 07:24 AM
Eric@Victory Racing's Avatar
Any of these short block will work for the application you described.
VRE 355LT1 Racer Shortblock-$3290.00 NO Core Charge
-Eagle 3.480” stroke 4340 Crankshaft, Eagle H-Beam Connecting Rods, SRP Pistons, Perfect Circle Rings, Clevite Main Bearings, Clevite Rod Bearings, Clevite Cam Bearings, ARP Main Studs
VRE 383LT1 Racer Shortblock-$3415.00 NO Core Charge
-Eagle 3.750” stroke 4340 Crankshaft, Eagle H-Beam Connecting Rods, SRP Pistons, Perfect Circle Rings , Clevite Main Bearings, Clevite Rod Bearings , Clevite Cam Bearings, ARP Main Studs
VRE 396LT1 Racer Shortblock-$3490.00 NO Core Charge
-Eagle 3.875” stroke 4340 Crankshaft, Eagle H-Beam Connecting Rods, SRP Pistons, Perfect Circle Rings, Clevite Main Bearings, Clevite Rod Bearings , Clevite Cam Bearings, ARP Main Studs
HectorM52
Parts Wanted
Feb 11, 2015 09:33 AM
11racing
Classic Engine Tech
Dec 26, 2014 05:40 PM
sskevinm
Dec 18, 2014 11:16 AM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
mjcent922
Jul 27, 2002 12:42 PM
