Non-Trac Ctrl Throttle Cable?
Old Mar 8, 2009 | 04:07 PM
Air-Adam's Avatar
Just a question... I have to replace the throttle cable on my '97 Z28 (T56 if it matters) and would like to remove the traction control system at the same time. What I would like to know, is this...
The only throttle cable GM lists for the LT1 w/o traction control is for the '94-96 cars. Will this one work with my '97?
Also, what needs to be done to properly disable the ASR system? I've heard it can be programmed out of the ECM, and that should do it. Is this all there is to it?
Old Mar 8, 2009 | 04:25 PM
Air-Adam's Avatar
Also... would I need a cruise control cable for a non-ASR car as well?
Old Mar 8, 2009 | 04:53 PM
Jlo's Avatar
Jlo
good luck trying to find the c.control cable I'm still looking for one...for the throttle cable I looked at hawksthirdgen.com they have the cable for like $20.00 or so..but I'd like to know more on how to fully remove the asr/tcs maybe removing the abs...so I'll give you a ttt..for more helpful info..
Old Mar 8, 2009 | 05:01 PM
Air-Adam's Avatar
Looks like GM Parts Direct lists both cables (throttle and cruise) for a '94-96... not expensive either? Don't see it being a problem to get from the dealer. Shows both cables listing around $30....?
I just need to know if they will work with my '97.
Old Mar 8, 2009 | 05:39 PM
ak95ta's Avatar
Yea it will work. If you can get them from GM parts direct then do it. I believe the cruise control cable is discontinued, I know it is for the 98-02 cars., but they still show it in their computer. Junk yards are your friend.
Old Mar 8, 2009 | 06:24 PM
maverickmk's Avatar
here's a good write up on how to remove the ASR: http://www.pharmacy.arizona.edu/staf...eadjuster.html
Old Mar 8, 2009 | 07:11 PM
ShownomercyZ28's Avatar
Quick question on the same topic as this, how do you adjust the throttle cable if you do this switch?
AtlasXVIII
Aug 24, 2015 11:41 PM
Aug 24, 2015 06:41 AM
Slayer
Aug 17, 2015 03:55 PM
detroitmuscle
Jul 31, 2015 04:21 AM
88IROC_Z
Jul 22, 2015 11:38 PM
